[mapguide-users] Tiling and other methods to improve performance
Kori Maleski
Kori.Maleski at websoftdev.com
Mon Sep 24 15:49:03 EDT 2007
Yes it will.
The Tiling Engine just does the math and requests, MapGuide will do the
generation based on what you specify.
Cheers,
Kori Maleski
Senior Application Developer
WEBSOFT DEVELOPERS, INC.
P: (530) 759-8754 ext 114
F: (530) 759-0923
kori.maleski at websoftdev.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George McLean
Sent: Monday, September 24, 2007 12:36 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Tiling and other methods to improve
performance
Hi Kori,
If I change the ImageFormat setting in serverconfig.ini from PNG to JPG
will the tiling engine create JPG images?
Thanks
George McLean
Kori Maleski wrote:
> It does, but there may be issues.
> Kori Maleski
> F: (530) 759-0923
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel, Brian
> Sent: Monday, September 24, 2007 11:33 AM
> Subject: RE: [mapguide-users] Tiling and other methods to improve
> performance
> Ok, Thanks. I thought I read in another thread that switching the DLL's
> and webconfig.ini would allow it to work with 1.2
> Brian Berdel
> McMahon Associates, Inc.
> p: 215.283.9444
> www.mcmtrans.com
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kori
> Maleski
> Sent: Monday, September 24, 2007 2:33 PM
> To: 'MapGuide Users Mail List'
> performance
> Working on MGO 1.2/ MGE2008 Release. Will have it up shortly.
> Kori Maleski
> F: (530) 759-0923
> Brian
> Sent: Monday, September 24, 2007 10:55 AM
> performance
> I have a repeating error when I try to use the tilingengine
> Title: Error
> Message: Resource data was not found: LayerGroupData
> StackTrace: Resource data was not found: LayerGroupData
> Exception occurred in method MgTagManager.GetTag at line 395 in file
> c:\build_bond_area\mapguide_open_source_v1.2\build_18.1\mgdev\server\src
> \services\resource\TagManager.cpp
> Date/Time: 9/24/2007 1:52:08 PM
> I am using 1.2
> C:\Program Files\Websoft Developers\FacilitiesMap Tiling
> Engine>"C:\Program File
> s\Websoft Developers\FacilitiesMap Tiling Engine\FmTilingEngine.exe" -u
> Administ
> rator -p admin -m SoleburyTwp
> Release Version 1.0.0
> -u user: Administrator
> -p password:***********
> -m map: SoleburyTwp
> -g group not specified
> -s scale not specified
> -sx not specified
> -sy not specified
> -ex not specified
> -ey not specified
> -l log not specified
> Preparing to Tile 'SoleburyTwp' Map Definition...
> Initializing Connection to MapGuide...Succeeded
> Tiling 'Base Layer Group' Layer Group...
> Scale: 1:98000 Finite Scale 1 of 12
> Tiles: 20 ( 5 Columns x 4 Rows )
> ...1...2...3
> Brian Berdel
> p: 215.283.9444
> www.mcmtrans.com
> McLean
> Sent: Thursday, September 20, 2007 11:26 AM
> performance
> Thanks again Kori. I will be upgrading today and hopefully will see
> beautiful panning maps!
> George
> Kori Maleski wrote:
>> George,
>> Upgrade to 1.2, since the tiled maping/base layer performance is much
>> better.
>> Then use the tiling engine to pre-tile just the area of interest at
> large
>> scales. Small scales you may tile the whole thing.
>> This will reduce the number of tiles significantly.
>> The tiling engine allows you to specify a bounding box in tile
> row/columns.
>> If you specify these bounds you can limit the tile generation to
> required
>> areas only. This will have to be done for each zoom threshold -
> easily done
>> with a batch script.
>> I generated a tiled base map for the entire state of California in
> this
>> manner. I tiled the entirety of all the small scale thresholds and
> then
>> just specific areas of interest (urban centres) at large scale
> thresholds.
>> To reduce tiles (and the amount of space they require) - try to reduce
> the
>> number of thresholds. Some may be unnecessary.
>> Cheers,
>> Kori Maleski
>> F: (530) 759-0923
> McLean
>> Sent: Wednesday, September 19, 2007 3:32 PM
>> Subject: [mapguide-users] Tiling and other methods to improve
> performance
>> Hello,
>> I have a large base map that covers an area for an electric utility.
> The
>> base map is in state plane grid coordinates and the map is about 100
>> miles in both X and Y. Most of this map in this 100x100 region is
> blank
>> since we only have base information near where the utility's
> facilities
>> are located. I am trying to improve performance by using tiles. I
> would
>> like to have zoom levels in pretty close, maybe on the order of 1:500
> as
>> well as zoom levels that much farther out. If I set this up with Base
>> Layers in studio and then generate tiles using Websoft's tiling engine
>> for each zoom level, I will get a huge number of tiles. If I do not
>> generate tiles then performance is perceived as poor.
>> Are there any better strategies for dealing with large base maps that
>> must be viewed both at the detail level and high zoom scales? I m
> still
>> using MGOS 1.1 (maybe I should upgrade).
>> Thanks,
>> George McLean
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
