[mapguide-users] postgis connection properties EMPTY!!!!!
Maciej Skorczewski
maciej.skorczewski at procad.pl
Tue Sep 25 07:50:21 EDT 2007
Try this steps.
1. Install MG 1.2 Stable version
2. Install Postgres 8.2.xx (), after that instal postgis extension.
3. Download PostgGIS provider
4. change provider.xml file in
C:\Program Files\MapGuideOpenSource\Server\Bin\FDO
(add this
<FeatureProvider>
<Name>OSGeo.PostGIS.3.2</Name>
<DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
<Description>FDO Provider for PostGIS</Description>
<IsManaged>False</IsManaged>
<Version>3.2.0.0</Version>
<FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
<LibraryPath>PostGISProvider.dll</LibraryPath>
</FeatureProvider>
5. restart serwer.
6. open Mg Studio->create new data connection->(in this place ypu should
have Postgis provider) -> if all is ok you should have 4 fields to enter
connection string.
dorra labidi pisze:
> Hi every body;
> I have reinstalled mapguide OS, web Studio and postgresql/postgis on my
> computer. I have also copied the postgisfdo provider DLL's and modified
> the providers.xml file. Finally I have copied the postgis bin folder to
> the bin folder of mapguide server OS.
> When I clic on "configure data connection", I find the postgis porvider
> in the list of providers.
> *The problem is that the "connection properties" fields are empty*:
> There is no username field nor password, schema and source field.
> The error message is :
> /An exception occurred in FDO component.
> Unable to load the FDO Provider: /
> Has anyone encountred this problem?
> Thank you very much for your help.
Maciej Skórczewski
PROCAD SA
Autodesk Authorized Value Added Reseller
www.procad.pl
