[mapguide-users] postgis connection properties EMPTY!!!!!
dorra2007 dorrdor at yahoo.fr
Wed Sep 26 02:52:00 EDT 2007
I have tried this steps. I have successfully connected to postgis with
windows XP home. Now I am using WinLSD and i wanted to redo exactly the same
steps, but I failed. I have always the 4 fields empty, no data to enter and
of course, can't establish connection to postgis.
Does the problem come from the operating system I use?
macieksk wrote:
> Try this steps.
> 1. Install MG 1.2 Stable version
> 2. Install Postgres 8.2.xx (), after that instal postgis extension.
> 3. Download PostgGIS provider
> 4. change provider.xml file in
> C:\Program Files\MapGuideOpenSource\Server\Bin\FDO
> (add this
>   <FeatureProvider>
>      <Name>OSGeo.PostGIS.3.2</Name>
>      <DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
>      <Description>FDO Provider for PostGIS</Description>
>      <IsManaged>False</IsManaged>
>      <Version>3.2.0.0</Version>
>      <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
>      <LibraryPath>PostGISProvider.dll</LibraryPath>
>    </FeatureProvider>
> 5. restart serwer.
> 6. open Mg Studio->create new data connection->(in this place ypu should
> have Postgis provider) -> if all is ok you should have 4 fields to enter
> connection string.
> dorra labidi pisze:
>> Hi every body;
>> I have reinstalled mapguide OS, web Studio and postgresql/postgis on my
>> computer. I have also copied the postgisfdo provider DLL's and modified
>> the providers.xml file. Finally I have copied the postgis bin folder to
>> the bin folder of mapguide server OS.
>> When I clic on "configure data connection", I find the postgis porvider
>> in the list of providers.
>> *The problem is that the "connection properties" fields are empty*:
>> There is no username field nor password, schema and source  field.
>> The error message is :
>> /An exception occurred in FDO component.
>> Unable to load the FDO Provider: /
>> Has anyone encountred this problem?
>> Thank you very much for your help.
> Maciej Skórczewski
> PROCAD SA
> Autodesk Authorized Value Added Reseller
> www.procad.pl
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/postgis-connection-properties-EMPTY%21%21%21%21%21-tf4514993s16610.html#a12895033
