[mapguide-users] postgis connection properties EMPTY!!!!!
    Kenneth, GEOGRAF A/S
    ks at geograf.dk
    Wed Sep 26 02:58:25 EDT 2007
The problem is that the PostGIS FDO Provider (as well as the other
providers) depend on certain Dll's being avalible.
I recommend using dependency walker to open the Dll, and view it
dependencies. It will highlight missing dll dependencies.
http://www.dependencywalker.com
Regards, Kenneth, GEOGRAF A/S
dorra2007 skrev:
> I have tried this steps. I have successfully connected to postgis with
> windows XP home. Now I am using WinLSD and i wanted to redo exactly the same
> steps, but I failed. I have always the 4 fields empty, no data to enter and
> of course, can't establish connection to postgis.
> Does the problem come from the operating system I use?
> macieksk wrote:
>> Try this steps.
>> 1. Install MG 1.2 Stable version
>> 2. Install Postgres 8.2.xx (), after that instal postgis extension.
>> 3. Download PostgGIS provider
>> 4. change provider.xml file in
>> C:\Program Files\MapGuideOpenSource\Server\Bin\FDO
>> (add this
>>   <FeatureProvider>
>>      <Name>OSGeo.PostGIS.3.2</Name>
>>      <DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
>>      <Description>FDO Provider for PostGIS</Description>
>>      <IsManaged>False</IsManaged>
>>      <Version>3.2.0.0</Version>
>>      <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
>>      <LibraryPath>PostGISProvider.dll</LibraryPath>
>>    </FeatureProvider>
>> 5. restart serwer.
>> 6. open Mg Studio->create new data connection->(in this place ypu should
>> have Postgis provider) -> if all is ok you should have 4 fields to enter
>> connection string.
>> dorra labidi pisze:
>>> Hi every body;
>>> I have reinstalled mapguide OS, web Studio and postgresql/postgis on my
>>> computer. I have also copied the postgisfdo provider DLL's and modified
>>> the providers.xml file. Finally I have copied the postgis bin folder to
>>> the bin folder of mapguide server OS.
>>> When I clic on "configure data connection", I find the postgis porvider
>>> in the list of providers.
>>> *The problem is that the "connection properties" fields are empty*:
>>> There is no username field nor password, schema and source  field.
>>> The error message is :
>>> /An exception occurred in FDO component.
>>> Unable to load the FDO Provider: /
>>> Has anyone encountred this problem?
>>> Thank you very much for your help.
>> Maciej Skórczewski
>> PROCAD SA
>> Autodesk Authorized Value Added Reseller
>> www.procad.pl
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070926/4483dec3/attachment.html
