[mapguide-users] MG 2.0 BUG...after GetSelectionXML
adman666 adam at aemsaustralia.com.au
Wed Apr 2 05:16:29 EDT 2008
I am also seeing a problem with the GetSelectionXML function. After I use it
the resource remains locked and I cannot perform any further actions against
until I logout and log back into the application.
I can normally select the feature and then delete or update it but since
updating to mgos2 I am getting this error:
Error: Please try your operation later as the resource was busy:
Library://AEMSDB/Actions/487/Data/11504.FeatureSource
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpUpdateFeatures.Execute line 111 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\OpUpdateFeatures.cpp
  - MgServerUpdateFeatures.UpdateFeatures line 131 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerUpdateFeatures.cpp
  - MgFdoConnectionManager.RemoveCachedFdoConnection line 1006 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\common\manager\FdoConnectionManager.cpp
I thought that I may have left a feature reader open somewhere but this is
definately not the case.
Kenneth, GEOGRAF A/S wrote:
> In one of the MapGuide versions, there was an error that would crash the
> service if the Xml pointed to a non-existent feature.
> I have not entered a bug ticket for it, because I have not yet tested
> for the bug in the release version.
> Are you 100% sure that the FeatureID corresponds to an existing item?
> Regards, Kenneth, GEOGRAF A/S
> Maciej Skorczewski skrev:
>>  ...this same in SetSelection :(
>> did you have this same error?
>> are there any change in API of MG 2.0 of this function?
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/MG-2.0-BUG...after-GetSelectionXML-tp16173707s16610p16445848.html
