[mapguide-users] MG 2.0 BUG...after GetSelectionXML
Maciej Skorczewski maciej.skorczewski at procad.pl
Wed Apr 2 07:23:00 EDT 2008
I have this same problem
http://trac.osgeo.org/mapguide/ticket/524
can you add your error code etx. to this ticket?
> Hi,
> I am also seeing a problem with the GetSelectionXML function. After I use it
> the resource remains locked and I cannot perform any further actions against
> until I logout and log back into the application.
> I can normally select the feature and then delete or update it but since
> updating to mgos2 I am getting this error:
> Error: Please try your operation later as the resource was busy:
> Library://AEMSDB/Actions/487/Data/11504.FeatureSource
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpUpdateFeatures.Execute line 111 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\OpUpdateFeatures.cpp
>   - MgServerUpdateFeatures.UpdateFeatures line 131 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerUpdateFeatures.cpp
>   - MgFdoConnectionManager.RemoveCachedFdoConnection line 1006 file
> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> I thought that I may have left a feature reader open somewhere but this is
> definately not the case.
> Kenneth, GEOGRAF A/S wrote:
>> In one of the MapGuide versions, there was an error that would crash the
>> service if the Xml pointed to a non-existent feature.
>> I have not entered a bug ticket for it, because I have not yet tested
>> for the bug in the release version.
>> Are you 100% sure that the FeatureID corresponds to an existing item?
>> Regards, Kenneth, GEOGRAF A/S
