[mapguide-users] MGOS 2.0: MgUpdateFeatures broken
Ismael Cams mapguide2007 at gmail.com
Thu Apr 3 08:57:13 EDT 2008
Hello,
I have written some code for inserting polygon, lines and points in SDF
files. This code was working fine on MGOS 1.2, but in MGOS 2.0
UpdateFeatures does not seem to work anymore. I get following error:
MgResourceBusyException
<2008-04-03T14:49:39> 			Administrator
 Error: Please try your operation later as the resource was busy:
Library://Schilde/Data/Mobiliteit/wegenwerken.FeatureSource
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpUpdateFeatures.Execute line 111 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\OpUpdateFeatures.cpp
  - MgServerUpdateFeatures.UpdateFeatures line 131 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerUpdateFeatures.cpp
  - MgFdoConnectionManager.RemoveCachedFdoConnection line 1006 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\common\manager\FdoConnectionManager.cpp
Has there been any change on this in the API ?
View this message in context: http://www.nabble.com/MGOS-2.0%3A-MgUpdateFeatures-broken-tp16467463s16610p16467463.html
