[mapguide-users] MGOS 2.0: MgUpdateFeatures broken
Zac Spitzer zac.spitzer at gmail.com
Thu Apr 3 10:16:48 EDT 2008
did you open a feature reader and not close it?
On Thu, Apr 3, 2008 at 11:57 PM, Ismael Cams <mapguide2007 at gmail.com> wrote:
>  Hello,
>  I have written some code for inserting polygon, lines and points in SDF
>  files. This code was working fine on MGOS 1.2, but in MGOS 2.0
>  UpdateFeatures does not seem to work anymore. I get following error:
>  MgResourceBusyException
>  <2008-04-03T14:49:39>                   Administrator
>   Error: Please try your operation later as the resource was busy:
>  Library://Schilde/Data/Mobiliteit/wegenwerken.FeatureSource
>   StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpUpdateFeatures.Execute line 111 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\OpUpdateFeatures.cpp
>   - MgServerUpdateFeatures.UpdateFeatures line 131 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerUpdateFeatures.cpp
>   - MgFdoConnectionManager.RemoveCachedFdoConnection line 1006 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\common\manager\FdoConnectionManager.cpp
>  Has there been any change on this in the API ?
>  View this message in context: http://www.nabble.com/MGOS-2.0%3A-MgUpdateFeatures-broken-tp16467463s16610p16467463.html
>  Sent from the MapGuide Users mailing list archive at Nabble.com.
>  _______________________________________________
>  mapguide-users mailing list
>  mapguide-users at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
