[mapguide-users] MGOS 2.0: Problem consuming WFS still exists
Don C. MacGregor
sir_sunkee at yahoo.ca
Thu Apr 3 12:01:47 EDT 2008
I am running MGOS 2.0 and can successfully connect to WFS server using
AutoCAD Map 3D 2008 but there is nothing in the list of layers.
Ismael Cams wrote:
> Hello,
> I tried the same procedure with MGOS 2.0 but the result is the same.
> Is this a bug (and can it tracked) or could it be a problem of the
> published WFS ?
> Ismael Cams wrote:
>> Hello,
>> I am using MGOS 1.2 and trying to consume WFS from following server:
>> http://www.gegis.org/gegis-1.2/wfs?
>> Although the layers and attributes are shown correctly in Mapguide Studio
>> I am not able to show the geometry. In the error.log there is following
>> error message:
>> Error: Failed to stylize layer: LayerDefinition3
>> An exception occurred in FDO component.
>> Schema can not be found in the collection.
>> In order to check if it might be a problem with the WFS server itself, I
>> have tried some other servers on the Internet too. But result is always
>> the same, no geometry is shown ...
>> Is this a result of GML inconsistencies ?
>> Can someone point me in the right direction what should be done to get
>> the connection working ?
>> Thanks in advance.
View this message in context: http://www.nabble.com/Mapguide-and-consuming-WFS%3A-does-it-work-for-someone---tp16180546s16610p16467779.html
