[mapguide-users] MGOS 2.0: Problem consuming WFS still exists
    Ismael Cams
    mapguide2007 at gmail.com
    Thu Apr  3 15:24:18 EDT 2008
Did you succeed with other WFS servers ? I did try some other online WFS
servers but without any result ...
Don C. MacGregor wrote:
> I am running MGOS 2.0 and can successfully connect to WFS server using
> AutoCAD Map 3D 2008 but there is nothing in the list of layers.
> Ismael Cams wrote:
>> Hello,
>> I tried the same procedure with MGOS 2.0 but the result is the same.
>> Is this a bug (and can it tracked) or could it be a problem of the
>> published WFS ?
>> Ismael Cams wrote:
>>> Hello,
>>> I am using MGOS 1.2 and trying to consume WFS from following server:
>>> http://www.gegis.org/gegis-1.2/wfs?
>>> Although the layers and attributes are shown correctly in Mapguide
>>> Studio I am not able to show the geometry. In the error.log there is
>>> following error message:
>>>    Error: Failed to stylize layer: LayerDefinition3
>>>         An exception occurred in FDO component.
>>>         Schema can not be found in the collection.
>>> In order to check if it might be a problem with the WFS server itself, I
>>> have tried some other servers on the Internet too. But result is always
>>> the same, no geometry is shown ...
>>> Is this a result of GML inconsistencies ?
>>> Can someone point me in the right direction what should be done to get
>>> the connection working ?
>>> Thanks in advance.
View this message in context: http://www.nabble.com/Mapguide-and-consuming-WFS%3A-does-it-work-for-someone---tp16180546s16610p16469587.html
