[mapguide-users] Make Selectable Layers
Sandeep Thosar
sandeepthosar at gmail.com
Fri Apr 4 02:26:01 EDT 2008
Hi Users,
I have .NET Framework 2005 and i installed OpenSource as per your
instructions provided in developer guide.
When i run the application i got number of errors in utilityfunction.aspx
for Ex. not a valid function or n number of syntax error then i use %@Page
Languge"C#"% on utilityfunction.aspx form then all error realted to syntax
are solved but stilled i could not run the application and i received error
There can be only one 'page ' directive and validation(): element "html"
occurs too few times.
I checked all source code but i did not get any duplication.
if there is already solution for this problem then please send me link.
With Regards,
Sandeep Thosar
On Fri, Apr 4, 2008 at 11:53 AM, Jackie Ng <jackie.ng at aecsystems.com.au>
wrote:
> Did you refresh the map afterwards? Maybe a refresh (manual or
> programmatic)
> is required to force the new setting to kick in.
> - Jackie
> Johnba wrote:
> > Hi List,
> > How can change a selectable layer to no selectable layer on execution
> > time
> > in the viewer map, I need if it's possible, I tryed with the
> SetSelectable
> > method but apparently it work when I create a new layer.
> > I appreciate any help
> > Thanks
> > John Bayron Molina Garcia
> > MicroCAD Lta. Web Developer
> > www.microcad.com.co
> > johnba.molina at gmail.com
> > http://www.johnba.com
> > http://www.usarte.org
> > Colombia
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Make-Selectable-Layers-tp16481765s16610p16485867.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080404/0164f50f/attachment.html
