[mapguide-users] can't update and delete from feature source but insert works
Ismael Cams mapguide2007 at gmail.com
Fri Apr 4 02:40:31 EDT 2008
Hello,
I started a thread on the forum yesterday similar to what you are
describing. Did you get any error messages (I get an
MgResourceBusyException) ? After I try to delete or update a feature I also
not succeed anymore to insert features. Only after a restart of mgserver I
can insert features again.
My code was working fine with MGOS 1.2.
J Manafi wrote:
> I am having a very similar problem. We are digitizing layers and storing
> temporary feature sources in the session repository, and I, too, cannot
> delete or update our temp. layers, but I can insert new features. I
> checked the readonly flag, but it was already set to FALSE, and my
> attempts at updating features are very similar programatically to the
> posts I have already come across.  We are able to do a mass deletion,
> however, and delete all temporary layers from the map, but I have been
> unsuccessful in trying to delete a singular feature from specific layers.
> Has anyone been able to make any progress on this topic?<br>
> mitcha wrote:
>> hello everybody,
>> i need help!!!  i try tu update and delete a feature source (sdf file),
>> but it doesn't work! instead inserting new data into feature source work
>> very well! i searched for solutions in this forum and i found some
>> similar problems.
>> So I first tried to set the readonly flag of the schema to false with the
>> mapagent. now the xml presentation looks like this:
>> <FeatureSource xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>> <Provider>OSGeo.SDF</Provider>
>> <Parameter>
>> <Name>File</Name>
>> <Value>%MG_DATA_FILE_PATH%userPoints2.sdf</Value>
>> </Parameter>
>> <Parameter>
>> <Name>ReadOnly</Name>
>> <Value>FALSE</Value>
>> </Parameter>
>> </FeatureSource>
>> But it doesn't work!!!
>> furthermore i tried to set the identity property to readonly="false" with
>> the help of Fdo2Fdo. But it doesn't work, too. i always get an error
>> message. Could this be my fault? can i change this value of the identity
>> property?
View this message in context: http://www.nabble.com/can%27t-update-and-delete-from-feature-source-but-insert-works-tp12233926s16610p16485878.html
