[mapguide-users] MGOS 2.0: MgUpdateFeatures broken
Zac Spitzer
zac.spitzer at gmail.com
Fri Apr 4 03:03:33 EDT 2008
if your refering to the thread 'Please try your operation later as the
resource was busy' from Adam
it was indeed a feature reader problem
On Fri, Apr 4, 2008 at 5:45 PM, Ismael Cams <mapguide2007 at gmail.com> wrote:
> The featurereader is closed. The identical code is behaving correct on MGOS
> 1.2.
> There is a parallel thread on the forum at the moment which is describing
> the same problem withe updating and deleting features. Might be a bug or
> changed behaviour ?
> did you open a feature reader and not close it?
> View this message in context: http://www.nabble.com/MGOS-2.0%3A-MgUpdateFeatures-broken-tp16467463s16610p16485938.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
