[mapguide-users] MGOS 2.0: MgUpdateFeatures broken
Ismael Cams mapguide2007 at gmail.com
Fri Apr 4 08:12:49 EDT 2008
You are right. It was indeed a FeatureReader problem. I was closing it, but
only after having done the update. Somehow it did not give problems in MGOS
1.2.
I have moved the close() before the deletion/update of the feature and it is
working fine now.
Thanks for the help.
zspitzer wrote:
> if your refering to the thread 'Please try your operation later as the
> resource was busy' from Adam
> it was indeed a feature reader problem
> On Fri, Apr 4, 2008 at 5:45 PM, Ismael Cams <mapguide2007 at gmail.com>
> wrote:
>>  The featurereader is closed. The identical code is behaving correct on
>> MGOS
>>  1.2.
>>  There is a parallel thread on the forum at the moment which is
>> describing
>>  the same problem withe updating and deleting features. Might be a bug or
>>  changed behaviour ?
>>  did you open a feature reader and not close it?
>>  View this message in context:
>> http://www.nabble.com/MGOS-2.0%3A-MgUpdateFeatures-broken-tp16467463s16610p16485938.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>  _______________________________________________
>>  mapguide-users mailing list
>>  mapguide-users at lists.osgeo.org
>>  http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
View this message in context: http://www.nabble.com/MGOS-2.0%3A-MgUpdateFeatures-broken-tp16467463s16610p16491215.html
