[mapguide-users] TaskPane problems on Fusion
Jackie Ng jackie.ng at aecsystems.com.au
Fri Apr 4 03:15:22 EDT 2008
I've had issues with the Task Pane widget too. I've documented my experiences
here:
http://trac.osgeo.org/fusion/ticket/36
Perhaps you could add extra notes here?
- Jackie
Katsuaki Soizumi wrote:
> I found a problem how TaskPane works at Fusion;
> [Home] button doesn't go back to the initial display.
> When I set as below,
>  start.aspx  -  URL that executes with TaskPane on start up
>  button.aspx -  URL that executes with InvokeURL on Toolbar (Target is
> TaskPane)
> and,
> 1. Display the initial screen of TaskPane
> 2. At this moment, [Previous] button is set as enable
> 3. Click [Previous] button and no content has change in the task pane
>    and [Previous] button is set as disable
> 4. Execute button.aspx, which is defined at Toolbar
> 5. TaskPane displays button.aspx
> 6. Click [Home] button but button.aspx stays!!
> This is clicking [Previous] button as example, but also,,
>  . do some operations
> 2. Click [Home] button => goto start.aspx
> 3. Executes InvokeURL(b1.aspx)
> 4. Click [Home] button => goto b1.aspx
> 5. Executes InvokeURL(b2.aspx)
> 6. Click [Home] button => goto b2.aspx
>  . and, so on..
> This process also displaces the URL (start.aspx) that assigned to [Home]
> button.
> Assuming the initial URL has changed to InvokeURL after clicking [Home]
> button.
> I think when clicking [Home] button, start.aspx at starting up always has
> to be displayed.
> Thanks in advance.
> Soizumi
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/TaskPane-problems-on-Fusion-tp16389680s16610p16486605.html
