[mapguide-users] can't update and delete from feature source but insert works
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Apr 4 12:23:04 EDT 2008
The $ID gets replaced by PHP, but FDO SQL requires that strings are quoted.
Change the line to:
|$filter = "KEY = '$ID'";
It is a bit annoying because you have to get the column type before you
can do the query.
Regards, Kenneth, GEOGRAF A/S
J Manafi skrev:
> Does anyone know...with an MgDeleteFeatures(or perhaps
> MgUpdateFeatures) command, does the filter string have to be of a
> certain type? For instance, we have features stored with a unique KEY
> value. It used to be of type 'Int32', and it seemed that
> DeleteFeatures was working back then. But then I changed the KEY value
> to type 'String' to make it more dynamic, and that seems to be when
> this breakdown started happening.
> Our filter string looks like this: |$filter = "KEY = $ID";|
> Should the fact that $ID is a string matter at all?
>     J Manafi wrote:
>     I have not received any error messages. All of our php script
>     files execute fine and return all the expected values through
>     FireBug as if they are executing correctly. I am also not seeing
>     your issue of not being able to insert anymore, because I have now
>     tried that, where I have an UpdateFeatures followed by an
>     InsertFeatures, and all of the features are getting inserted every
>     time but not updated. I have taken the advice of the other threads
>     and tried closing any and all featureReaders I could find, but
>     that has had no effect.
>     Just for reference, I am using MG 1.2 with bundled php environment.
>     Does anyone have any more suggestions?
>     Thanks in advance for any help you give.
>         Ismael Cams wrote:
>         Hello, I started a thread on the forum yesterday similar to
>         what you are describing. Did you get any error messages (I get
>         an MgResourceBusyException) ? After I try to delete or update
>         a feature I also not succeed anymore to insert features. Only
>         after a restart of mgserver I can insert features again. My
>         code was working fine with MGOS 1.2.
>             J Manafi wrote:
>             I am having a very similar problem. We are digitizing
>             layers and storing temporary feature sources in the
>             session repository, and I, too, cannot delete or update
>             our temp. layers, but I can insert new features. I checked
>             the readonly flag, but it was already set to FALSE, and my
>             attempts at updating features are very similar
>             programatically to the posts I have already come across.
>             We are able to do a mass deletion, however, and delete all
>             temporary layers from the map, but I have been
>             unsuccessful in trying to delete a singular feature from
>             specific layers. Has anyone been able to make any progress
>             on this topic?
>                 mitcha wrote:
>                 hello everybody, i need help!!! i try tu update and
>                 delete a feature source (sdf file), but it doesn't
>                 work! instead inserting new data into feature source
>                 work very well! i searched for solutions in this forum
>                 and i found some similar problems. So I first tried to
>                 set the readonly flag of the schema to false with the
>                 mapagent. now the xml presentation looks like this:
>                 OSGeo.SDF File %MG_DATA_FILE_PATH%userPoints2.sdf
>                 ReadOnly FALSE But it doesn't work!!! furthermore i
>                 tried to set the identity property to readonly="false"
>                 with the help of Fdo2Fdo. But it doesn't work, too. i
>                 always get an error message. Could this be my fault?
>                 can i change this value of the identity property? . . .
> View this message in context: Re: can't update and delete from feature
> <http://www.nabble.com/can%27t-update-and-delete-from-feature-source-but-insert-works-tp12233926s16610p16492944.html>
> Sent from the MapGuide Users mailing list archive
> <http://www.nabble.com/MapGuide-Users-f14845.html> at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080404/6e5b3c43/attachment.html
