[mapguide-users] can't update and delete from feature source
but insert works
Jonathan Manafi
jonathan.manafi at cctechnol.com
Fri Apr 4 12:32:33 EDT 2008
After all this head-scratching and the blank stares, it turned out to be
two unused quotes. Ughhh, that's aggravating. :-)
Thank you for your quick, extremely helpful response
Kenneth, GEOGRAF A/S wrote:
> The $ID gets replaced by PHP, but FDO SQL requires that strings are
> quoted.
> Change the line to:
> |$filter = "KEY = '$ID'";
> It is a bit annoying because you have to get the column type before
> you can do the query.
> Regards, Kenneth, GEOGRAF A/S
> J Manafi skrev:
>> Does anyone know...with an MgDeleteFeatures(or perhaps
>> MgUpdateFeatures) command, does the filter string have to be of a
>> certain type? For instance, we have features stored with a unique KEY
>> value. It used to be of type 'Int32', and it seemed that
>> DeleteFeatures was working back then. But then I changed the KEY
>> value to type 'String' to make it more dynamic, and that seems to be
>> when this breakdown started happening.
>> Our filter string looks like this: |$filter = "KEY = $ID";|
>> Should the fact that $ID is a string matter at all?
>> J Manafi wrote:
>> I have not received any error messages. All of our php script
>> files execute fine and return all the expected values through
>> FireBug as if they are executing correctly. I am also not seeing
>> your issue of not being able to insert anymore, because I have
>> now tried that, where I have an UpdateFeatures followed by an
>> InsertFeatures, and all of the features are getting inserted
>> every time but not updated. I have taken the advice of the other
>> threads and tried closing any and all featureReaders I could
>> find, but that has had no effect.
>> Just for reference, I am using MG 1.2 with bundled php environment.
>> Does anyone have any more suggestions?
>> Thanks in advance for any help you give.
>> Ismael Cams wrote:
>> Hello, I started a thread on the forum yesterday similar to
>> what you are describing. Did you get any error messages (I
>> get an MgResourceBusyException) ? After I try to delete or
>> update a feature I also not succeed anymore to insert
>> features. Only after a restart of mgserver I can insert
>> features again. My code was working fine with MGOS 1.2.
>> J Manafi wrote:
>> I am having a very similar problem. We are digitizing
>> layers and storing temporary feature sources in the
>> session repository, and I, too, cannot delete or update
>> our temp. layers, but I can insert new features. I
>> checked the readonly flag, but it was already set to
>> FALSE, and my attempts at updating features are very
>> similar programatically to the posts I have already come
>> across. We are able to do a mass deletion, however, and
>> delete all temporary layers from the map, but I have been
>> unsuccessful in trying to delete a singular feature from
>> specific layers. Has anyone been able to make any
>> progress on this topic?
>> mitcha wrote:
>> hello everybody, i need help!!! i try tu update and
>> delete a feature source (sdf file), but it doesn't
>> work! instead inserting new data into feature source
>> work very well! i searched for solutions in this
>> forum and i found some similar problems. So I first
>> tried to set the readonly flag of the schema to false
>> with the mapagent. now the xml presentation looks
>> like this: OSGeo.SDF File
>> %MG_DATA_FILE_PATH%userPoints2.sdf ReadOnly FALSE But
>> it doesn't work!!! furthermore i tried to set the
>> identity property to readonly="false" with the help
>> of Fdo2Fdo. But it doesn't work, too. i always get an
>> error message. Could this be my fault? can i change
>> this value of the identity property? . . .
>> View this message in context: Re: can't update and delete from
>> feature source but insert works
>> <http://www.nabble.com/can%27t-update-and-delete-from-feature-source-but-insert-works-tp12233926s16610p16492944.html>
>> Sent from the MapGuide Users mailing list archive
>> <http://www.nabble.com/MapGuide-Users-f14845.html> at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080404/fa9552c9/attachment.html
