[mapguide-users] help drawing on map use Mapguide 1.2 api
Kenneth, GEOGRAF A/S
ks at geograf.dk
Tue Apr 8 04:14:18 EDT 2008
The easy way of doing this, would be to create a featuresource that
points to the database.
If the database has x,y columns, that would enable this without programming.
You can style the points (size, symbol, color, theme etc) in a layer.
If you want to do something more advanced, you must create a temporary
featuresource, and insert your data into this temporary source.
Then you can create/re-use a layer to display this data.
There is C# code for this in the buffer sample, in the viewer folder of
the installation.
You can get the developer guide and API help files from the program
shortcut that was installed when you installed MapGuide (assuming you
did no de-select the documentation).
Regards, Kenneth, GEOGRAF A/S
Justin Driskell skrev:
> Hello I am new to mapguide. I am using Mapguide 1.2 and IIS/Dot. I am writing a function that will be used by my website (in CS) to grab coordinates of sites from a database. Then using the Mapguide API I will plot on the map those sites. Can you direct me to where I can get Mapguide API help. I already have the Mapguide API documentation but I need a little help getting to the right function to do the job. Does Mapguide have a function like drawCircle(location, layer).
> Thanks in advanced
> Justin Driskell
> Engineer 1
> (770)-989-9488
> jdriskel at scires.com
> Scientific Research Corporation
> 2300 Windy Ridge Parkway
> Suite 400 South
> Atlanta, GA 30339
> 770-859-9161 (phone)
> 770-859-9315 (fax)
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
