[mapguide-users] multiple raster folders
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue Apr 8 07:03:09 EDT 2008
You must select the file from the list below, you are trying to create a
package, which requires a repository path, not a file system path.
Regards, Kenneth, GEOGRAF A/S
Sandeep Thosar skrev:
> Dear Saso Slibar,
> After i changing the file Extension from zip to Mgp and load file
> again then i get following error
> *Cannot create package From_Map Guide_20080408_C\Program
> Files\MapGuideOpenSource2.0\Server\Packages\Sheboygan.mgp from folder
> C:\Program Files\MapGuideOpenSource2.0\Server\Packages\Sheboygan.mgp:
> Invalid resource name: C:\Program
> Files\MapGuideOpenSource2.0\Server\Packages\Sheboygan.mgp*
> *Please help me.*
> *With Regards,*
> *Sandeep*
> 2008/4/8 Sandeep Thosar <sandeepthosar at gmail.com
> <mailto:sandeepthosar at gmail.com>>:
>     Dear Sašo Šlibar,
>     I am chaning the Extension from Zip to mgp and reload the file and
>     give full path but still it show me same error.
>     Please help me out.
>     With Regards,
>     Sandeep
>     2008/4/8 Sašo Šlibar <saso at sl-king.si <mailto:saso at sl-king.si>>:
>         it's a mistake on sample package filename.
>         rename extension from .zip to .mgp and load it again
>         Lep pozdrav,
>         Sašo Šlibar
>         *From:* mapguide-users-bounces at lists.osgeo.org
>         <mailto:mapguide-users-bounces at lists.osgeo.org>
>         [mailto:mapguide-users-bounces at lists.osgeo.org
>         <mailto:mapguide-users-bounces at lists.osgeo.org>] *On Behalf Of
>         *Sandeep Thosar
>         *Sent:* Tuesday, April 08, 2008 11:56 AM
>         *To:* MapGuide Users Mail List
>         *Subject:* Re: [mapguide-users] multiple raster folders
>         Dear All,
>         When load the sample data using the site Administrator in that
>         when i choose option Manage Packages then i get following
>         Error Cannot **create package From_Map
>         Guide_20080408_D\Sheboygan from folder D:\Sheboygan: Invalid
>         resource name: D:\Sheboygan**
>         I Download the Sheboygan.mgp file which is zip file then i
>         unzipped the same.
>         Please help me out.
>         Awaiting for your reply.
>         With Regards,
>         Sandeep
>         What is the best way to connect to raster images, which are in
>         different folders.
>         Is there any substitute to RasterImageCatalogue?
>         Why Gdal data source connection does not recognize images in
>         subfolders?
>         Best regards,
>         Sašo Šlibar
>         _______________________________________________
>         mapguide-users mailing list
>         mapguide-users at lists.osgeo.org
>         <mailto:mapguide-users at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080408/981a0292/attachment.html
