[mapguide-users] multiple raster folders
Sandeep Thosar
sandeepthosar at gmail.com
Tue Apr 8 07:41:12 EDT 2008
Dear Kenneth,
I can't get your point can you please clarify the same.
With Regards,
Sandeep
2008/4/8 Kenneth, GEOGRAF A/S <ks at geograf.dk>:
> You must select the file from the list below, you are trying to create a
> package, which requires a repository path, not a file system path.
> Regards, Kenneth, GEOGRAF A/S
> Sandeep Thosar skrev:
> Dear Saso Slibar,
> After i changing the file Extension from zip to Mgp and load file again
> then i get following error
> *Cannot create package From_Map Guide_20080408_C\Program
> Files\MapGuideOpenSource2.0\Server\Packages\Sheboygan.mgp from folder
> C:\Program Files\MapGuideOpenSource2.0\Server\Packages\Sheboygan.mgp:
> Invalid resource name: C:\Program
> Files\MapGuideOpenSource2.0\Server\Packages\Sheboygan.mgp*
> *Please help me.*
> *With Regards,*
> *Sandeep*
> 2008/4/8 Sandeep Thosar <sandeepthosar at gmail.com>:
> > Dear Sašo Šlibar,
> > I am chaning the Extension from Zip to mgp and reload the file and give
> > full path but still it show me same error.
> > Please help me out.
> > With Regards,
> > Sandeep
> > 2008/4/8 Sašo Šlibar <saso at sl-king.si>:
> > > it's a mistake on sample package filename.
> > > rename extension from .zip to .mgp and load it again
> > > Lep pozdrav,
> > > Sašo Šlibar
> > > *From:* mapguide-users-bounces at lists.osgeo.org [mailto:
> > > mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Sandeep Thosar
> > > *Sent:* Tuesday, April 08, 2008 11:56 AM
> > > *To:* MapGuide Users Mail List
> > > *Subject:* Re: [mapguide-users] multiple raster folders
> > > Dear All,
> > > When load the sample data using the site Administrator in that when i
> > > choose option Manage Packages then i get following Error Cannot *create
> > > package From_Map Guide_20080408_D\Sheboygan from folder D:\Sheboygan:
> > > Invalid resource name: D:\Sheboygan*
> > > I Download the Sheboygan.mgp file which is zip file then i unzipped
> > > the same.
> > > Please help me out.
> > > Awaiting for your reply.
> > > With Regards,
> > > Sandeep
> > > What is the best way to connect to raster images, which are in
> > > different folders.
> > > Is there any substitute to RasterImageCatalogue?
> > > Why Gdal data source connection does not recognize images in
> > > subfolders?
> > > Best regards,
> > > Sašo Šlibar
> > > _______________________________________________
> > > mapguide-users mailing list
> > > mapguide-users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080408/9b18500c/attachment.html
