[mapguide-users] Data Package Problem
Kenneth, GEOGRAF A/S ks at geograf.dk
Wed Apr 9 03:39:14 EDT 2008
Did you read the the guide?
http://mapguide.osgeo.org/2.0/documentation.html
Click on "Getting Started with MapGuide".
Which step is failing?
.Net/IIS uses slightly different urls:
 http://localhost/mapguide/mapadmin/login.php
 http://localhost/mapguide/dotnetviewersample/ajaxtiledviewersample.aspx
You seem to confuse repository paths with file system paths.
The WebLayout is not on the filesystem, but in the repository, so you
cannot find it from windows explorer.
You must use an authoring tool to edit the WebLayout (links are in the
guide).
For more information on how MapGuide works, please see the Developers Guide:
Simply click on "MapGuide Developers Guide".
Regards, Kenneth, GEOGRAF A/S
Sandeep Thosar skrev:
> Dear Rahul,
> Thanks for the information but when i debug this page it shows me
> UserId= Anonymous and Password="" then create session after that it
> goes to
> frame id="viewerFrame" frameborder="no" marginwidth="0"
> marginheight="0" scrolling="no"
> src="../mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId%>&WEBLAYOUT=<%=webLayout%>">
> where i get session information and shows WebLayout path
> Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout and then
> get blank output so where i stroes this Library folder in my
> application folder or currently it stored in C:\Program
> Files\MapGuideOpenSource2.0\Server\Packages\Library\Samples\Sheboygan\Layouts.
> Please help me.
> With Regards,
> Sandeep
> On Wed, Apr 9, 2008 at 10:17 AM, Rahul <unicorn_admirer at yahoo.com
> <mailto:unicorn_admirer at yahoo.com>> wrote:
>     Hi ,
>              I think you should check
>     www/dotnetviewersample/_*ajaxviewersample.aspx*_ file , this file
>     contain the information regarding the weblayout as well as the
>     startup page for the sample application.
>     <script runat="server">
>     String webLayout =
>     "Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
>     String defaultUser = "Anonymous";
>     String defaultPassword = "";
>     String sessionId = "";
>     </script>
>     Max !!
>     ----- Original Message ----
>     From: Sandeep Thosar <sandeepthosar at gmail.com
>     <mailto:sandeepthosar at gmail.com>>
>     To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org
>     <mailto:mapguide-users at lists.osgeo.org>>
>     Sent: Wednesday, April 9, 2008 11:33:13 AM
>     Subject: Re: [mapguide-users] Data Package Problem
>     Dear Rahul,
>     I use Asp.Net 2.0 and i load packages also but what is the start
>     up page i set to run the application.
>     my WebLayout stored in C:\Program
>     and the path which returned in JAvascript is
>     I can't understand from where WebLayout Picked.
>     Please help me.
>     With Regards,
>     Sandeep
>     On Wed, Apr 9, 2008 at 9:53 AM, Rahul <unicorn_admirer at yahoo.com
>         Hi ,
>                  I think you try to check through MapAgent and see
>         that you can get some xml output for the Feature Source loaded
>         through Data Package(*.mgp).
>         http://x.x.x.x:8008/mapguide/mapagent/
>         One more thing are you using MapGuide Studio and if so then
>         you can check the loaded package and see that you can preview
>         weblayout or layers in the mapguide studio.
>         Max
>         Dear Rahul,
>         After i load data packages from site administrator and i run
>         my application then i get blank output without any Error.
>         Please told me exactly what happen and which page i set to
>         start up page for the mapguide application or there is any
>         changes require in mapguide open source sample code.
>         Please help me.
>         With Regards,
>         Sandeep
>         You rock. That's why Blockbuster's offering you one month of
>         Blockbuster Total Access
>         <http://us.rd.yahoo.com/evt=47523/*http://tc.deals.yahoo.com/tc/blockbuster/text5.com>,
>         No Cost.
>         _______________________________________________
>         mapguide-users mailing list
>         http://lists.osgeo.org/mailman/listinfo/mapguide-users
>     __________________________________________________
>     Do You Yahoo!?
>     Tired of spam? Yahoo! Mail has the best spam protection around
>     http://mail.yahoo.com <http://mail.yahoo.com/>
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080409/242d4f10/attachment.html
