[mapguide-users] Data Package Problem
Sandeep Thosar
sandeepthosar at gmail.com
Wed Apr 9 04:53:25 EDT 2008
Dear Kenneth, GEOGRAF ,
Thanks for the mail.
I After I installed data packages then it give me one log file
Sheboygan.mgp.log but when I run the sample code it give me blank output
again.
Please help me.
With Regards,
Sandeep
On Wed, Apr 9, 2008 at 1:09 PM, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
> Did you read the the guide?
> http://mapguide.osgeo.org/2.0/documentation.html
> Click on "Getting Started with MapGuide".
> Which step is failing?
> .Net/IIS uses slightly different urls:
> http://localhost/mapguide/mapadmin/login.php
> http://localhost/mapguide/dotnetviewersample/ajaxtiledviewersample.aspx
> You seem to confuse repository paths with file system paths.
> The WebLayout is not on the filesystem, but in the repository, so you
> cannot find it from windows explorer.
> You must use an authoring tool to edit the WebLayout (links are in the
> guide).
> For more information on how MapGuide works, please see the Developers
> Guide:
> Simply click on "MapGuide Developers Guide".
> Regards, Kenneth, GEOGRAF A/S
> Sandeep Thosar skrev:
> Dear Rahul,
> Thanks for the information but when i debug this page it shows me UserId=
> Anonymous and Password="" then create session after that it goes to
> frame id="viewerFrame" frameborder="no" marginwidth="0" marginheight="0"
> scrolling="no" src="../mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId%>
> &WEBLAYOUT=<%=webLayout%>"> where i get session information and shows
> WebLayout path Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout
> and then get blank output so where i stroes this Library folder in my
> application folder or currently it stored in C:\Program
> Files\MapGuideOpenSource2.0\Server\Packages\Library\Samples\Sheboygan\Layouts. Please
> help me.
> With Regards,
> Sandeep
> On Wed, Apr 9, 2008 at 10:17 AM, Rahul <unicorn_admirer at yahoo.com> wrote:
> > Hi ,
> > I think you should check www/dotnetviewersample/*
> > ajaxviewersample.aspx* file , this file contain the information
> > regarding the weblayout as well as the startup page for the sample
> > application.
> > <script runat="server">
> > String webLayout =
> > "Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
> > String defaultUser = "Anonymous";
> > String defaultPassword = "";
> > String sessionId = "";
> > </script>
> > Max !!
> > ----- Original Message ----
> > From: Sandeep Thosar <sandeepthosar at gmail.com>
> > To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> > Sent: Wednesday, April 9, 2008 11:33:13 AM
> > Subject: Re: [mapguide-users] Data Package Problem
> > Dear Rahul,
> > I use Asp.Net 2.0 and i load packages also but what is the start up page
> > i set to run the application.
> > my WebLayout stored in C:\Program
> > and the path which returned in JAvascript is
> > I can't understand from where WebLayout Picked.
> > Please help me.
> > With Regards,
> > Sandeep
> > On Wed, Apr 9, 2008 at 9:53 AM, Rahul <unicorn_admirer at yahoo.com> wrote:
> > > Hi ,
> > > I think you try to check through MapAgent and see that you
> > > can get some xml output for the Feature Source loaded through Data
> > > Package(*.mgp).
> > > http://x.x.x.x:8008/mapguide/mapagent/
> > > One more thing are you using MapGuide Studio and if so then you can
> > > check the loaded package and see that you can preview weblayout or layers in
> > > the mapguide studio.
> > > Max
> > > Dear Rahul,
> > > After i load data packages from site administrator and i run my
> > > application then i get blank output without any Error.
> > > Please told me exactly what happen and which page i set to start up
> > > page for the mapguide application or there is any changes require in
> > > mapguide open source sample code.
> > > Please help me.
> > > With Regards,
> > > Sandeep
> > > You rock. That's why Blockbuster's offering you one month of
> > > Blockbuster Total Access<http://us.rd.yahoo.com/evt=47523/*http://tc.deals.yahoo.com/tc/blockbuster/text5.com>,
> > > No Cost.
> > > _______________________________________________
> > > mapguide-users mailing list
> > > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > __________________________________________________
> > Do You Yahoo!?
> > Tired of spam? Yahoo! Mail has the best spam protection around
> > http://mail.yahoo.com
> mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080409/0f03a15d/attachment.html
