[mapguide-users] Data Package Problem
Kenneth, GEOGRAF A/S
ks at geograf.dk
Wed Apr 9 05:05:17 EDT 2008
What sample code are you refering to?
If you try the link below:
http://localhost/mapguide/dotnetviewersample/ajaxtiledviewersample.aspx
It should ask you for username/password.
Regards, Kenneth, GEOGRAF A/S
Sandeep Thosar skrev:
> Dear Kenneth, GEOGRAF ,
> Thanks for the mail.
> I After I installed data packages then it give me one log file
> Sheboygan.mgp.log but when I run the sample code it give me blank
> output again.
> Please help me.
> With Regards,
> Sandeep
> On Wed, Apr 9, 2008 at 1:09 PM, Kenneth, GEOGRAF A/S <ks at geograf.dk
> <mailto:ks at geograf.dk>> wrote:
> Did you read the the guide?
> http://mapguide.osgeo.org/2.0/documentation.html
> Click on "Getting Started with MapGuide".
> Which step is failing?
> .Net/IIS uses slightly different urls:
> http://localhost/mapguide/mapadmin/login.php
> You seem to confuse repository paths with file system paths.
> The WebLayout is not on the filesystem, but in the repository, so
> you cannot find it from windows explorer.
> You must use an authoring tool to edit the WebLayout (links are in
> the guide).
> For more information on how MapGuide works, please see the
> Developers Guide:
> Simply click on "MapGuide Developers Guide".
>> Dear Rahul,
>> Thanks for the information but when i debug this page it shows me
>> UserId= Anonymous and Password="" then create session after that
>> it goes to
>> frame id="viewerFrame" frameborder="no" marginwidth="0"
>> marginheight="0" scrolling="no"
>> src="../mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId%>&WEBLAYOUT=<%=webLayout%>">
>> where i get session information and shows WebLayout path
>> Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout and
>> then get blank output so where i stroes this Library folder in my
>> application folder or currently it stored in C:\Program
>> Files\MapGuideOpenSource2.0\Server\Packages\Library\Samples\Sheboygan\Layouts.
>> Please help me.
>> With Regards,
>> Sandeep
>> On Wed, Apr 9, 2008 at 10:17 AM, Rahul <unicorn_admirer at yahoo.com
>> <mailto:unicorn_admirer at yahoo.com>> wrote:
>> Hi ,
>> I think you should check
>> www/dotnetviewersample/_*ajaxviewersample.aspx*_ file , this
>> file contain the information regarding the weblayout as well
>> as the startup page for the sample application.
>> <script runat="server">
>> String webLayout =
>> "Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
>> String defaultUser = "Anonymous";
>> String defaultPassword = "";
>> String sessionId = "";
>> </script>
>> Max !!
>> ----- Original Message ----
>> From: Sandeep Thosar <sandeepthosar at gmail.com
>> <mailto:sandeepthosar at gmail.com>>
>> To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org
>> <mailto:mapguide-users at lists.osgeo.org>>
>> Sent: Wednesday, April 9, 2008 11:33:13 AM
>> Subject: Re: [mapguide-users] Data Package Problem
>> Dear Rahul,
>> I use Asp.Net 2.0 and i load packages also but what is the
>> start up page i set to run the application.
>> my WebLayout stored in C:\Program
>> and the path which returned in JAvascript is
>> I can't understand from where WebLayout Picked.
>> Please help me.
>> With Regards,
>> Sandeep
>> On Wed, Apr 9, 2008 at 9:53 AM, Rahul
>> Hi ,
>> I think you try to check through MapAgent and
>> see that you can get some xml output for the Feature
>> Source loaded through Data Package(*.mgp).
>> http://x.x.x.x:8008/mapguide/mapagent/
>> One more thing are you using MapGuide Studio and if so
>> then you can check the loaded package and see that you
>> can preview weblayout or layers in the mapguide studio.
>> Max
>> Dear Rahul,
>> After i load data packages from site administrator and i
>> run my application then i get blank output without any Error.
>> Please told me exactly what happen and which page i set
>> to start up page for the mapguide application or there is
>> any changes require in mapguide open source sample code.
>> Please help me.
>> With Regards,
>> Sandeep
>> You rock. That's why Blockbuster's offering you one month
>> of Blockbuster Total Access
>> <http://us.rd.yahoo.com/evt=47523/*http://tc.deals.yahoo.com/tc/blockbuster/text5.com>,
>> No Cost.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> __________________________________________________
>> Do You Yahoo!?
>> Tired of spam? Yahoo! Mail has the best spam protection around
>> http://mail.yahoo.com <http://mail.yahoo.com/>
>> _______________________________________________ mapguide-users
>> mailing list mapguide-users at lists.osgeo.org
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080409/f8385a9c/attachment.html
