[mapguide-users] Data Package Problem
Sandeep Thosar
sandeepthosar at gmail.com
Wed Apr 9 05:48:37 EDT 2008
I refering the dotnetviewersamplecode from download page and then unziped
the sample code to C:\Inetpub\wwwroot directory and when i clicked on this
linked i get message page can't find and if i run my application then i get
blank output.
Please help me.
With Regards,
Sandeep
On Wed, Apr 9, 2008 at 2:35 PM, Kenneth, GEOGRAF A/S <ks at geograf.dk> wrote:
> What sample code are you refering to?
> If you try the link below:
> http://localhost/mapguide/dotnetviewersample/ajaxtiledviewersample.aspx
> It should ask you for username/password.
> Regards, Kenneth, GEOGRAF A/S
> Sandeep Thosar skrev:
> Dear Kenneth, GEOGRAF ,
> Thanks for the mail.
> I After I installed data packages then it give me one log file
> Sheboygan.mgp.log but when I run the sample code it give me blank output
> again.
> Please help me.
> With Regards,
> Sandeep
> On Wed, Apr 9, 2008 at 1:09 PM, Kenneth, GEOGRAF A/S <ks at geograf.dk>
> wrote:
> > Did you read the the guide?
> > http://mapguide.osgeo.org/2.0/documentation.html
> > Click on "Getting Started with MapGuide".
> > Which step is failing?
> > .Net/IIS uses slightly different urls:
> > http://localhost/mapguide/mapadmin/login.php
> > You seem to confuse repository paths with file system paths.
> > The WebLayout is not on the filesystem, but in the repository, so you
> > cannot find it from windows explorer.
> > You must use an authoring tool to edit the WebLayout (links are in the
> > guide).
> > For more information on how MapGuide works, please see the Developers
> > Guide:
> > Simply click on "MapGuide Developers Guide".
> > Dear Rahul,
> > Thanks for the information but when i debug this page it shows me
> > UserId= Anonymous and Password="" then create session after that it goes to
> > frame id="viewerFrame" frameborder="no" marginwidth="0" marginheight="0"
> > scrolling="no" src="../mapviewernet/ajaxviewer.aspx?SESSION=
> > <%=sessionId%>&WEBLAYOUT=<%=webLayout%>"> where i get session
> > information and shows WebLayout path Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout
> > and then get blank output so where i stroes this Library folder in my
> > application folder or currently it stored in C:\Program
> > Files\MapGuideOpenSource2.0\Server\Packages\Library\Samples\Sheboygan\Layouts. Please
> > help me.
> > With Regards,
> > Sandeep
> > On Wed, Apr 9, 2008 at 10:17 AM, Rahul <unicorn_admirer at yahoo.com>
> > wrote:
> > > Hi ,
> > > I think you should check www/dotnetviewersample/*
> > > ajaxviewersample.aspx* file , this file contain the information
> > > regarding the weblayout as well as the startup page for the sample
> > > application.
> > > <script runat="server">
> > > String webLayout =
> > > "Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
> > > String defaultUser = "Anonymous";
> > > String defaultPassword = "";
> > > String sessionId = "";
> > > </script>
> > > Max !!
> > > ----- Original Message ----
> > > From: Sandeep Thosar <sandeepthosar at gmail.com>
> > > To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
> > > Sent: Wednesday, April 9, 2008 11:33:13 AM
> > > Subject: Re: [mapguide-users] Data Package Problem
> > > Dear Rahul,
> > > I use Asp.Net 2.0 and i load packages also but what is the start up
> > > page i set to run the application.
> > > my WebLayout stored in C:\Program
> > > and the path which returned in JAvascript is
> > > I can't understand from where WebLayout Picked.
> > > Please help me.
> > > With Regards,
> > > Sandeep
> > > On Wed, Apr 9, 2008 at 9:53 AM, Rahul <unicorn_admirer at yahoo.com>
> > > wrote:
> > > > Hi ,
> > > > I think you try to check through MapAgent and see that you
> > > > can get some xml output for the Feature Source loaded through Data
> > > > Package(*.mgp).
> > > > http://x.x.x.x:8008/mapguide/mapagent/
> > > > One more thing are you using MapGuide Studio and if so then you can
> > > > check the loaded package and see that you can preview weblayout or layers in
> > > > the mapguide studio.
> > > > Max
> > > > Dear Rahul,
> > > > After i load data packages from site administrator and i run my
> > > > application then i get blank output without any Error.
> > > > Please told me exactly what happen and which page i set to start up
> > > > page for the mapguide application or there is any changes require in
> > > > mapguide open source sample code.
> > > > Please help me.
> > > > With Regards,
> > > > Sandeep
> > > > You rock. That's why Blockbuster's offering you one month of
> > > > Blockbuster Total Access<http://us.rd.yahoo.com/evt=47523/*http://tc.deals.yahoo.com/tc/blockbuster/text5.com>,
> > > > No Cost.
> > > > _______________________________________________
> > > > mapguide-users mailing list
> > > > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> > > __________________________________________________
> > > Do You Yahoo!?
> > > Tired of spam? Yahoo! Mail has the best spam protection around
> > > http://mail.yahoo.com
> > mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080409/83f0b866/attachment.html
