[mapguide-users] Data Package Problem
Kenneth, GEOGRAF A/S ks at geograf.dk
Wed Apr 9 09:21:06 EDT 2008
In the guide, step 2 is:
2. Download and extract the sample application.
    Visit the downloads page and download phpviewersample-2.0.zip. *On
Windows extract the files to C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www*. On Linux extract the
    files to /usr/local/mapguideopensource/webserverextensions/www. Note
that in both cases it should create a folder called phpviewersample
under www.
I have made the important part bold.
For dotnet, the folder is called dotnetviewersample instead of
phpviewersample.
Regards, Kenneth, GEOGRAF A/S
Sandeep Thosar skrev:
> I refering the dotnetviewersamplecode from download page and then
> unziped the sample code to C:\Inetpub\wwwroot directory and when i
> clicked on this linked i get message page can't find and if i run my
> application then i get blank output.
> Please help me.
> With Regards,
> Sandeep
> On Wed, Apr 9, 2008 at 2:35 PM, Kenneth, GEOGRAF A/S <ks at geograf.dk
> <mailto:ks at geograf.dk>> wrote:
>     What sample code are you refering to?
>     If you try the link below:
>     http://localhost/mapguide/dotnetviewersample/ajaxtiledviewersample.aspx
>     It should ask you for username/password.
>>     Dear  Kenneth, GEOGRAF ,
>>     Thanks for the mail.
>>     I After I installed data packages then it give me one log file
>>     Sheboygan.mgp.log but when I run the sample code it give me blank
>>     output again.
>>     Please help me.
>>     With Regards,
>>     Sandeep
>>     On Wed, Apr 9, 2008 at 1:09 PM, Kenneth, GEOGRAF A/S
>>     <ks at geograf.dk <mailto:ks at geograf.dk>> wrote:
>>         Did you read the the guide?
>>         http://mapguide.osgeo.org/2.0/documentation.html
>>         Click on "Getting Started with MapGuide".
>>         Which step is failing?
>>         .Net/IIS uses slightly different urls:
>>          http://localhost/mapguide/mapadmin/login.php
>>         You seem to confuse repository paths with file system paths.
>>         The WebLayout is not on the filesystem, but in the
>>         repository, so you cannot find it from windows explorer.
>>         You must use an authoring tool to edit the WebLayout (links
>>         are in the guide).
>>         For more information on how MapGuide works, please see the
>>         Developers Guide:
>>         Simply click on "MapGuide Developers Guide".
>>>         Dear Rahul,
>>>         Thanks for the information but when i debug this page it
>>>         shows me UserId= Anonymous and Password="" then create
>>>         session after that it goes to
>>>         frame id="viewerFrame" frameborder="no" marginwidth="0"
>>>         marginheight="0" scrolling="no"
>>>         src="../mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId%>&WEBLAYOUT=<%=webLayout%>">
>>>         where i get session information and shows WebLayout path
>>>         Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout
>>>         and then get blank output so where i stroes this Library
>>>         folder in my application folder or currently it stored in
>>>         C:\Program
>>>         Files\MapGuideOpenSource2.0\Server\Packages\Library\Samples\Sheboygan\Layouts.
>>>         Please help me.
>>>         With Regards,
>>>         Sandeep
>>>         On Wed, Apr 9, 2008 at 10:17 AM, Rahul
>>>         <unicorn_admirer at yahoo.com
>>>         <mailto:unicorn_admirer at yahoo.com>> wrote:
>>>             Hi ,
>>>                      I think you should check
>>>             www/dotnetviewersample/_*ajaxviewersample.aspx*_ file ,
>>>             this file contain the information regarding the
>>>             weblayout as well as the startup page for the sample
>>>             application.
>>>             <script runat="server">
>>>             String webLayout =
>>>             "Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout";
>>>             String defaultUser = "Anonymous";
>>>             String defaultPassword = "";
>>>             String sessionId = "";
>>>             </script>
>>>             Max !!
>>>             ----- Original Message ----
>>>             From: Sandeep Thosar <sandeepthosar at gmail.com
>>>             <mailto:sandeepthosar at gmail.com>>
>>>             To: MapGuide Users Mail List
>>>             <mapguide-users at lists.osgeo.org
>>>             <mailto:mapguide-users at lists.osgeo.org>>
>>>             Sent: Wednesday, April 9, 2008 11:33:13 AM
>>>             Subject: Re: [mapguide-users] Data Package Problem
>>>             Dear Rahul,
>>>             I use Asp.Net 2.0 and i load packages also but what is
>>>             the start up page i set to run the application.
>>>             my WebLayout stored in C:\Program
>>>             and the path which returned in JAvascript is
>>>             I can't understand from where WebLayout Picked.
>>>             Please help me.
>>>             With Regards,
>>>             Sandeep
>>>             On Wed, Apr 9, 2008 at 9:53 AM, Rahul
>>>                 Hi ,
>>>                          I think you try to check through MapAgent
>>>                 and see that you can get some xml output for the
>>>                 Feature Source loaded through Data Package(*.mgp).
>>>                 http://x.x.x.x:8008/mapguide/mapagent/
>>>                 One more thing are you using MapGuide Studio and if
>>>                 so then you can check the loaded package and see
>>>                 that you can preview weblayout or layers in the
>>>                 mapguide studio.
>>>                 Max
>>>                 Dear Rahul,
>>>                 After i load data packages from site administrator
>>>                 and i run my application then i get blank output
>>>                 without any Error.
>>>                 Please told me exactly what happen and which page i
>>>                 set to start up page for the mapguide application or
>>>                 there is any changes require in mapguide open source
>>>                 sample code.
>>>                 Please help me.
>>>                 With Regards,
>>>                 Sandeep
>>>                 You rock. That's why Blockbuster's offering you one
>>>                 month of Blockbuster Total Access
>>>                 <http://us.rd.yahoo.com/evt=47523/*http://tc.deals.yahoo.com/tc/blockbuster/text5.com>,
>>>                 No Cost.
>>>                 _______________________________________________
>>>                 mapguide-users mailing list
>>>                 http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>             __________________________________________________
>>>             Do You Yahoo!?
>>>             Tired of spam? Yahoo! Mail has the best spam protection
>>>             around
>>>             http://mail.yahoo.com <http://mail.yahoo.com/>
>>>         mapguide-users mailing list mapguide-users at lists.osgeo.org
>>     _______________________________________________ mapguide-users
>     mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080409/d3b14099/attachment.html
