[mapguide-users] ODBC problems....MGOS 2.0
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Apr 10 15:58:51 EDT 2008
I have added the column stuff to MapStudio OS, but I have not yet built
a new release.
If you have access to a Visual Studio 2003 (or newer) it should be no
problem to build one yourself.
I am currently building an browser for unmanged resources, and I will
release it after that.
Regards, Kenneth, GEOGRAF A/S
Andrew DeMerchant skrev:
> Ah! I had to change the MG Server service to run on the correct
> account.....though, I DID (prior to that) try (and fail) to enter the
> correct credentials right in the provider settings. anyway, that did
> it.....now on to the next problem:
> How the heck am I supposed to actually _make_ a new ODBC connection??
> In Autodesk Studio, I can at least now see my tables, and select which
> fields to use as the geometry fields (not so in MapStudioOS) - but
> when I try to save it, I get the following:
> I'd do it in MapStudioOS, but there doesn't seem to be a place to pick
> my x and y columns...And we all know that WebStudio's not so useful
> for this either....This "upgrade" to 2.0 sure is starting to feel like
> a bad idea.
> Andrew
> Dave Wilson wrote:
>> The database connections are compatible and should work. Reasons why
>> they might not work:
>> When using connection strings the ODBC driver name is different
>> between the machines or does not match the string. The DSN names are
>> not the same or do not exist.
>> Are the databases local to the server? If not did you change your MG
>> server process to use an account with network access?
>> Regards,
>> Dave
>> *From:* mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
>> DeMerchant
>> *Sent:* Thursday, April 10, 2008 8:44 AM
>> *To:* MapGuide Users Mail List
>> *Subject:* [mapguide-users] ODBC problems....MGOS 2.0
>> I'm trying to start to migrate to MGOS 2.0 (from 1.0.2)....I've got a
>> test machine running MGOS 2.0 right now, and am testing out just
>> moving my packages from my production server to my test server. Not
>> surprisingly, any dataconnections I had set up on my production
>> server stop working on my dev server - I assume because they were
>> made using FDO 3.1, while MGOS 2 uses FDO 3.2 (it'd be awfully nice
>> if the FDO people would make things backwards compatible). Anyway, I
>> fully expected those to break (along with my Raster layers).
>> I've hit a wall in trying to get them (my ODBC datasources) set up
>> again. I've tried in Autodesk Studio, I've tried in MapStudioOS -
>> neither are working. They both give me an error that is the same -
>> "An exception occurred in FDO component. RDBMS: No current open
>> database."....I've tried custom connection strings and DSN (which is
>> my preferred method). Same result for both. I did successfully
>> connect to an SQL server I have onsite, but that's not where my data
>> is. That suggests to me the the problem may be with my database
>> format - which is Jet (MS Access). What the solution here? If all
>> else fails, is it an option for me to install FDO3.1 with MGOS2?
>> Andrew
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
Skipped content of type multipart/related
