[mapguide-users] ODBC problems....MGOS 2.0
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Apr 10 16:03:54 EDT 2008
I don't have access to that - so I'll wait. How long till you release
that? I know that's a tough question, but are we talking days, weeks or
months?
Andrew
Kenneth, GEOGRAF A/S wrote:
> I have added the column stuff to MapStudio OS, but I have not yet
> built a new release.
> If you have access to a Visual Studio 2003 (or newer) it should be no
> problem to build one yourself.
> I am currently building an browser for unmanged resources, and I will
> release it after that.
> Regards, Kenneth, GEOGRAF A/S
> Andrew DeMerchant skrev:
>> Ah! I had to change the MG Server service to run on the correct
>> account.....though, I DID (prior to that) try (and fail) to enter the
>> correct credentials right in the provider settings. anyway, that did
>> it.....now on to the next problem:
>> How the heck am I supposed to actually _make_ a new ODBC connection??
>> In Autodesk Studio, I can at least now see my tables, and select
>> which fields to use as the geometry fields (not so in MapStudioOS) -
>> but when I try to save it, I get the following:
>> I'd do it in MapStudioOS, but there doesn't seem to be a place to
>> pick my x and y columns...And we all know that WebStudio's not so
>> useful for this either....This "upgrade" to 2.0 sure is starting to
>> feel like a bad idea.
>> Andrew
>> Dave Wilson wrote:
>>> The database connections are compatible and should work. Reasons why
>>> they might not work:
>>> When using connection strings the ODBC driver name is different
>>> between the machines or does not match the string. The DSN names are
>>> not the same or do not exist.
>>> Are the databases local to the server? If not did you change your MG
>>> server process to use an account with network access?
>>> Regards,
>>> Dave
>>> *From:* mapguide-users-bounces at lists.osgeo.org
>>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
>>> *Andrew DeMerchant
>>> *Sent:* Thursday, April 10, 2008 8:44 AM
>>> *To:* MapGuide Users Mail List
>>> *Subject:* [mapguide-users] ODBC problems....MGOS 2.0
>>> I'm trying to start to migrate to MGOS 2.0 (from 1.0.2)....I've got
>>> a test machine running MGOS 2.0 right now, and am testing out just
>>> moving my packages from my production server to my test server. Not
>>> surprisingly, any dataconnections I had set up on my production
>>> server stop working on my dev server - I assume because they were
>>> made using FDO 3.1, while MGOS 2 uses FDO 3.2 (it'd be awfully nice
>>> if the FDO people would make things backwards compatible). Anyway, I
>>> fully expected those to break (along with my Raster layers).
>>> I've hit a wall in trying to get them (my ODBC datasources) set up
>>> again. I've tried in Autodesk Studio, I've tried in MapStudioOS -
>>> neither are working. They both give me an error that is the same -
>>> "An exception occurred in FDO component. RDBMS: No current open
>>> database."....I've tried custom connection strings and DSN (which is
>>> my preferred method). Same result for both. I did successfully
>>> connect to an SQL server I have onsite, but that's not where my data
>>> is. That suggests to me the the problem may be with my database
>>> format - which is Jet (MS Access). What the solution here? If all
>>> else fails, is it an option for me to install FDO3.1 with MGOS2?
>>> Andrew
>>> *Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.1-877-2GEMTEC x.163
>>> fax 506-453-9470
>>> /GEMTEC Limited <http://www.gemtec.ca>
>>> /191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
