[mapguide-users] ODBC problems....MGOS 2.0
Kenneth, GEOGRAF A/S ks at geograf.dk
Thu Apr 10 16:16:54 EDT 2008
I'm hoping it will be complete within the next week, but it's not a
promise :)
Regards, Kenneth, GEOGRAF A/S
Andrew DeMerchant skrev:
> I don't have access to that - so I'll wait. How long till you release
> that? I know that's a tough question, but are we talking days, weeks
> or months?
> Andrew
> Kenneth, GEOGRAF A/S wrote:
>> I have added the column stuff to MapStudio OS, but I have not yet
>> built a new release.
>> If you have access to a Visual Studio 2003 (or newer) it should be no
>> problem to build one yourself.
>> I am currently building an browser for unmanged resources, and I will
>> release it after that.
>>> Ah! I had to change the MG Server service to run on the correct
>>> account.....though, I DID (prior to that) try (and fail) to enter
>>> the correct credentials right in the provider settings. anyway, that
>>> did it.....now on to the next problem:
>>> How the heck am I supposed to actually _make_ a new ODBC
>>> connection?? In Autodesk Studio, I can at least now see my tables,
>>> and select which fields to use as the geometry fields (not so in
>>> MapStudioOS) - but when I try to save it, I get the following:
>>> I'd do it in MapStudioOS, but there doesn't seem to be a place to
>>> pick my x and y columns...And we all know that WebStudio's not so
>>> useful for this either....This "upgrade" to 2.0 sure is starting to
>>> feel like a bad idea.
>>> Andrew
>>> Dave Wilson wrote:
>>>> The database connections are compatible and should work. Reasons
>>>> why they might not work:
>>>> When using connection strings the ODBC driver name is different
>>>> between the machines or does not match the string. The DSN names
>>>> are not the same or do not exist.
>>>> Are the databases local to the server? If not did you change your
>>>> MG server process to use an account with network access?
>>>> Regards,
>>>> Dave
>>>> *From:* mapguide-users-bounces at lists.osgeo.org
>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
>>>> *Andrew DeMerchant
>>>> *Sent:* Thursday, April 10, 2008 8:44 AM
>>>> *To:* MapGuide Users Mail List
>>>> *Subject:* [mapguide-users] ODBC problems....MGOS 2.0
>>>> I'm trying to start to migrate to MGOS 2.0 (from 1.0.2)....I've got
>>>> a test machine running MGOS 2.0 right now, and am testing out just
>>>> moving my packages from my production server to my test server. Not
>>>> surprisingly, any dataconnections I had set up on my production
>>>> server stop working on my dev server - I assume because they were
>>>> made using FDO 3.1, while MGOS 2 uses FDO 3.2 (it'd be awfully nice
>>>> if the FDO people would make things backwards compatible). Anyway,
>>>> I fully expected those to break (along with my Raster layers).
>>>> I've hit a wall in trying to get them (my ODBC datasources) set up
>>>> again. I've tried in Autodesk Studio, I've tried in MapStudioOS -
>>>> neither are working. They both give me an error that is the same -
>>>> "An exception occurred in FDO component. RDBMS: No current open
>>>> database."....I've tried custom connection strings and DSN (which
>>>> is my preferred method). Same result for both. I did successfully
>>>> connect to an SQL server I have onsite, but that's not where my
>>>> data is. That suggests to me the the problem may be with my
>>>> database format - which is Jet (MS Access). What the solution here?
>>>> If all else fails, is it an option for me to install FDO3.1 with
>>>> MGOS2?
>>>> Andrew
>>>> *Andrew DeMerchant*
>>>> *Computer Technologist*
>>>> ph.1-877-2GEMTEC x.163
>>>> fax 506-453-9470
>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>> /191 Doak Road
>>>> Fredericton, NB, Canada
>>>> E3C 2E6
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> 	*Andrew DeMerchant*
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
Skipped content of type multipart/related
