[mapguide-users] ODBC problems....MGOS 2.0
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Apr 10 16:07:36 EDT 2008
It's the latest preview version (just downloaded it this week)....1.2.0.1403
Jason Birch wrote:
> Andrew, what version of Studio are you using?
> I haven't seen this error, but then I haven't had to create ODBC
> connections either...
> Jason
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Thursday, April 10, 2008 12:19
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] ODBC problems....MGOS 2.0
> Ah! I had to change the MG Server service to run on the correct
> account.....though, I DID (prior to that) try (and fail) to enter the
> correct credentials right in the provider settings. anyway, that did
> it.....now on to the next problem:
> How the heck am I supposed to actually _make_ a new ODBC connection??
> In Autodesk Studio, I can at least now see my tables, and select which
> fields to use as the geometry fields (not so in MapStudioOS) - but
> when I try to save it, I get the following:
> I'd do it in MapStudioOS, but there doesn't seem to be a place to pick
> my x and y columns...And we all know that WebStudio's not so useful
> for this either....This "upgrade" to 2.0 sure is starting to feel like
> a bad idea.
> Andrew
> Dave Wilson wrote:
> The database connections are compatible and should work. Reasons why
> they might not work:
> When using connection strings the ODBC driver name is different
> between the machines or does not match the string. The DSN names are
> not the same or do not exist.
> Are the databases local to the server? If not did you change your MG
> server process to use an account with network access?
> Regards,
> Dave
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> DeMerchant
> *Sent:* Thursday, April 10, 2008 8:44 AM
> *Subject:* [mapguide-users] ODBC problems....MGOS 2.0
> I'm trying to start to migrate to MGOS 2.0 (from 1.0.2)....I've got a
> test machine running MGOS 2.0 right now, and am testing out just
> moving my packages from my production server to my test server. Not
> surprisingly, any dataconnections I had set up on my production server
> stop working on my dev server - I assume because they were made using
> FDO 3.1, while MGOS 2 uses FDO 3.2 (it'd be awfully nice if the FDO
> people would make things backwards compatible). Anyway, I fully
> expected those to break (along with my Raster layers).
> I've hit a wall in trying to get them (my ODBC datasources) set up
> again. I've tried in Autodesk Studio, I've tried in MapStudioOS -
> neither are working. They both give me an error that is the same - "An
> exception occurred in FDO component. RDBMS: No current open
> database."....I've tried custom connection strings and DSN (which is
> my preferred method). Same result for both. I did successfully connect
> to an SQL server I have onsite, but that's not where my data is. That
> suggests to me the the problem may be with my database format - which
> is Jet (MS Access). What the solution here? If all else fails, is it
> an option for me to install FDO3.1 with MGOS2?
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
