[mapguide-users] ODBC problems....MGOS 2.0
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri Apr 11 03:03:39 EDT 2008
Thanks for the kind words.
You can actually customize the WebLayout, but it is not intuitive.
To create a custom command, click on the document icon to the right.
Select the command that will be the base of your new command.
Click the Add button, select "Custom item" and select the newly created
command.
Ideas for improvement are greatly appreciated, and you may enter them here:
http://code.google.com/p/mapstudioos/issues/list
Regards, Kenneth, GEOGRAF A/S
Andrew DeMerchant skrev:
> That's cool - just looking for some rough idea. Thanks - That program
> is getting really really close to doing everything that Autodesk's
> does (only better and faster). The only other thing it needs to do is
> to let you add tools and customize the toolbars etc in a weblayout,
> then it'll be a perfect replacement.
> Andrew
> Kenneth, GEOGRAF A/S wrote:
>> I'm hoping it will be complete within the next week, but it's not a
>> promise :)
>>> I don't have access to that - so I'll wait. How long till you
>>> release that? I know that's a tough question, but are we talking
>>> days, weeks or months?
>>> Andrew
>>>> I have added the column stuff to MapStudio OS, but I have not yet
>>>> built a new release.
>>>> If you have access to a Visual Studio 2003 (or newer) it should be
>>>> no problem to build one yourself.
>>>> I am currently building an browser for unmanged resources, and I
>>>> will release it after that.
>>>>> Ah! I had to change the MG Server service to run on the correct
>>>>> account.....though, I DID (prior to that) try (and fail) to enter
>>>>> the correct credentials right in the provider settings. anyway,
>>>>> that did it.....now on to the next problem:
>>>>> How the heck am I supposed to actually _make_ a new ODBC
>>>>> connection?? In Autodesk Studio, I can at least now see my tables,
>>>>> and select which fields to use as the geometry fields (not so in
>>>>> MapStudioOS) - but when I try to save it, I get the following:
>>>>> I'd do it in MapStudioOS, but there doesn't seem to be a place to
>>>>> pick my x and y columns...And we all know that WebStudio's not so
>>>>> useful for this either....This "upgrade" to 2.0 sure is starting
>>>>> to feel like a bad idea.
>>>>> Andrew
>>>>> Dave Wilson wrote:
>>>>>> The database connections are compatible and should work. Reasons
>>>>>> why they might not work:
>>>>>> When using connection strings the ODBC driver name is different
>>>>>> between the machines or does not match the string. The DSN names
>>>>>> are not the same or do not exist.
>>>>>> Are the databases local to the server? If not did you change your
>>>>>> MG server process to use an account with network access?
>>>>>> Regards,
>>>>>> Dave
>>>>>> *From:* mapguide-users-bounces at lists.osgeo.org
>>>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of
>>>>>> *Andrew DeMerchant
>>>>>> *Sent:* Thursday, April 10, 2008 8:44 AM
>>>>>> *To:* MapGuide Users Mail List
>>>>>> *Subject:* [mapguide-users] ODBC problems....MGOS 2.0
>>>>>> I'm trying to start to migrate to MGOS 2.0 (from 1.0.2)....I've
>>>>>> got a test machine running MGOS 2.0 right now, and am testing out
>>>>>> just moving my packages from my production server to my test
>>>>>> server. Not surprisingly, any dataconnections I had set up on my
>>>>>> production server stop working on my dev server - I assume
>>>>>> because they were made using FDO 3.1, while MGOS 2 uses FDO 3.2
>>>>>> (it'd be awfully nice if the FDO people would make things
>>>>>> backwards compatible). Anyway, I fully expected those to break
>>>>>> (along with my Raster layers).
>>>>>> I've hit a wall in trying to get them (my ODBC datasources) set
>>>>>> up again. I've tried in Autodesk Studio, I've tried in
>>>>>> MapStudioOS - neither are working. They both give me an error
>>>>>> that is the same - "An exception occurred in FDO component.
>>>>>> RDBMS: No current open database."....I've tried custom connection
>>>>>> strings and DSN (which is my preferred method). Same result for
>>>>>> both. I did successfully connect to an SQL server I have onsite,
>>>>>> but that's not where my data is. That suggests to me the the
>>>>>> problem may be with my database format - which is Jet (MS
>>>>>> Access). What the solution here? If all else fails, is it an
>>>>>> option for me to install FDO3.1 with MGOS2?
>>>>>> Andrew
>>>>>> *Andrew DeMerchant*
>>>>>> *Computer Technologist*
>>>>>> ph.1-877-2GEMTEC x.163
>>>>>> fax 506-453-9470
>>>>>> /GEMTEC Limited <http://www.gemtec.ca>
>>>>>> /191 Doak Road
>>>>>> Fredericton, NB, Canada
>>>>>> E3C 2E6
>>>>>> _______________________________________________
>>>>>> mapguide-users mailing list
>>>>>> mapguide-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>     *Andrew DeMerchant*
>>>>> fax 506-453-9470
>>>>> /191 Doak Road
>>>>> E3C 2E6
>>>     *Andrew DeMerchant*
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
