[mapguide-users] ODBC problems....MGOS 2.0
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Fri Apr 11 10:21:53 EDT 2008
That did it!! Thanks for the tip...My project just uses an arbitrary
system (well, according to MGOS anyway) so I never bother to do anything
with the coords - and usually Studio defaults to Arbitrary XY. Anyway,
that did it. Thanks again!
Andrew
Ben Schalley wrote:
> I saw this error just today on a clients system when using Autodesk MapGuide
> Studio. It seemed to be solved after setting a correct coordinate system.
> You can set the coordinate system below the grid with the tables.
> Maybe this helps...
> andrew.demerchant wrote:
>> How the heck am I supposed to actually _make_ a new ODBC connection?? In
>> Autodesk Studio, I can at least now see my tables, and select which
>> fields to use as the geometry fields (not so in MapStudioOS) - but when
>> I try to save it, I get the following:
>> http://www.nabble.com/file/p16627826/moz-screenshot-1.jpg
> Ben Schalley
> Analyst-Programmer
> Geo-IT BVBA
> | Silicon Building – Wilrijkstraat 37 | 2140 Antwerp | Belgium
> Tel: +32 (0)3/272 03 13 | Mobile: +32 (0)475/96 59 48 | Fax: +32 (0)3/272 03
> 14
> Web: http://www.geoit.be
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
