[mapguide-users] MGOS 2.0 - mrsid problem...
Mon Apr 14 12:47:02 EDT 2008
Andrew DeMerchant wrote:
> I've got some MrSid files that are being displayed (incorrectly) like
> the attached image. The images are air photos...it's as though the layer
> is making nearly every other layer transparent or white.
Andrew,
Any possibility the files are not actually 8bit?  Can you run gdalinfo
against one of the files to get a report?  You can install and use the
gdalinfo from FWTools 2.1.0 or so to get a report.
   http://home.gdal.org/fwtools/FWTools210.exe
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
