[mapguide-users] MGOS 2.0 - mrsid problem...
Jason Birch
Jason.Birch at nanaimo.ca
Mon Apr 14 14:46:54 EDT 2008
That's truly bizarre; this should not depend on whether you're using
.sid files or not. Are these layers that you created with an earlier
version of MapGuide?
I'd be interested in seeing the results of GetResourceContent for one of
the misbehaving feature sources
http://localhost/mapguide/mapagent/getresourcecontentform.html
as well as the contents of your providers.xml or the results of this
call:
http://localhost/mapguide/mapagent/getfeatureprovidersform.html
My guess would have been that something isn't quite right (location of
the MrSID dlls or something) but the error message doesn't seem right
for that.
Jason
Subject: Re: [mapguide-users] MGOS 2.0 - mrsid problem...
Jason: Yes, I followed those instructions...I've turned on debugging for
mgos and checked out the error.log - what looks to be my problem is that
it thinks the fdo isn't registered. I get "FDO Provider Not Registered"
for each mrsid layer. I've looked in Nabble to see if I could find a
solution, but no luck. Lots of people with that same problem (some for
the Raster FDO, some for others), but no one ever posted a solution.
Again, my other rasters are working (jpg, tiff), just not mrsid.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080414/1b3605a7/attachment.html
