[mapguide-users] Unable to load DLL 'MapGuideUnmanagedApi'
cgrell craig.grell at talus-tech.com
Tue Apr 15 11:55:44 EDT 2008
Thank you for the reply.
Yes it is an ASP.Net Application. I did copy all the dll files into the bin
folder but that didnt help. I had also tried the path you listed. Again did
not help.
I do have it working right now but I do not know what caused it to start
working. If I reboot I will go through this again.
Kenneth, GEOGRAF A/S wrote:
> I assume that you are trying to compile an ASP.Net WebApplication.
> You can copy all the .dll files from the bin folder in the webserver
> extensions into the bin folder of your project.
> Other than that, I think the path is:
> C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\bin
> It might work after your get a preview or start the viewer some other
> way, because once the Dll is correctly loaded by some process, it is
> avalible for the entire IIS application pool.
> Regards, Kenneth, GEOGRAF A/S
> cgrell skrev:
>> I keep getting thie error randomly
>> Unable to load DLL 'MapGuideUnmanagedApi': The specified module could not
>> be
>> found. (Exception from HRESULT: 0x8007007E)
>> Everything will be working then I reboot the computer and this error
>> starts
>> to occur. I then reboot the computer, restart the web service, restart
>> the
>> mapguide service and recomile in a random order until the error finally
>> goes
>> away.
>> I have added C:\Program Files\MapGuideOpenSource\WebServerExtensions\www
>> to
>> the path
>> I am using MapGuide 1.2
>> What might be causing this error and how can I troubleshoot this?
>> Thank you
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Unable-to-load-DLL-%27MapGuideUnmanagedApi%27-tp16680894s16610p16701426.html
