[mapguide-users] Properties Frame in Studio 2007 - Hyperlinks
Vishaal
vs2k2000 at rediffmail.com
Thu Apr 17 03:08:38 EDT 2008
Hi Andy,
i am also in the process of doing something similar as you have already
done. i want to zoom in to the specific parcel from the list of available
parcel, and want to display the image in the tool tip. my solution is made
using the shp files and VS2005 C#,MGOS 1.2. i am successful in getting the
list of selected parcel , now i want to follow something related to your
solution. if you can share your code with me then it will be a great help
for me as i have to submit this project very soon as a part of my
curriculum.
thanks for all your help. waiting for a positive reply.
thanks.
vishal
Andy Morsell wrote:
> Brad,
> Yes, the AJAX callbacks for tooltips in MGOS can exhibit strange behaviors
> if the it takes too long for that tooltip to display (as in my case where
> the property photo thumbnail is produced by server-side processing for
> each
> tooltip on the fly). I brought this particular issue up with the
> developers
> about 6 months ago and it apparently has not been fixed. The problem does
> not occur in Firefox.
> Andy
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
> Sent: Monday, January 29, 2007 7:09 AM
> To: 'MapGuide Users Mail List'
> Subject: RE: [mapguide-users] Properties Frame in Studio 2007 - Hyperlinks
> On Andy's Spokane page...
> Looking further, Andy is there some issue with refresh in the tooltip? I
> notice that if the window is active (IE7) and I hover on a parcel the tab
> shows as busy (spinning?) and the tooltip flashes. If I go to the ctrl
> click
> window the map settles down and displays the tootip correctly (constant).
> However the assessors info page is on top. Is this what everyone else
> sees?
> Sent: Monday, January 29, 2007 8:29 AM
> This is very disappointing as a 6.5 user. Nearly every point layer I have
> has a double click link on the icon for viewing the image of...
> I also use a narrowed layer list and NO frames for maximum map window.
> WAHHH!
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of James Card
> Sent: Saturday, January 27, 2007 12:26 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Properties Frame in Studio 2007 - Hyperlinks
> On Fri, 26 Jan 2007 18:05:56 -0800, <Jeff_Hobbs at sjwater.com> wrote:
>> I have a number of URLs in my table attributes. I have these columns
>> appearing in my Properties frame in MG Studio. Is there a way to
>> enable these URLs so that on the onClick event, the user goes to the
>> respective URL?
> The way we've done this is to include the HTML link syntax in the
> database;
> so, instead of storing 'http://someserver/scanned_image.png', we store '
> http://someserver/scanned_image.png View Image '.
> There is an example of this at <URL: http://demos2.calcad.com/RABA/ >.
> Select one of the Bus Route lines.
> James Card
> California CAD Solutions, Inc.
> 209 578-5580
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Properties-Frame-in-Studio-2007---Hyperlinks-tp8662120s16610p16740164.html
