[mapguide-users] .NET Fusion
Berdel, Brian
brian.berdel at mcmtrans.com
Thu Apr 17 13:59:33 EDT 2008
Mike it actually does because I am able to use the featurereader...I
just cannot open a map. Anyone know how to get the ID?
Brian Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mike Adair
Sent: Thursday, April 17, 2008 12:51 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] .NET Fusion
Fusion itself doesn't run under .NET, at least as far as I know.
Mike
Jackie C. Ng wrote:
> The reason I ask is that fusion does map names differently from the
normal
> ajax viewer. I think it's of the form [MapName][some long guid]
instead of
> [MapName]
> - Jackie
> Berdel, Brian wrote:
>> Hi Jackie,
>> I am actually passing it via a session variable from another Sub. It
is
>> the correct value. And like I said the code does work in the regular
>> Ajax viewer.
>> String smgMap = (Session["smgMap"]).ToString();
>> Brian
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie C
Ng
>> Sent: Wednesday, April 16, 2008 8:45 PM
>> To: mapguide-users at lists.osgeo.org
>> Where are you getting that value of the variable smgMap ?
>> - Jackie
>>> If I try to access a map via .net fusion I always get this
>> error...Code
>>> works fine in regular viewer. I have heard conflicting reports of
>>> Fusion and .NET can someone please clarify?
>>> MgUserInformation userInfo = new MgUserInformation(mgSessionId);
>>> MgSiteConnection siteConnection = new MgSiteConnection();
>>> siteConnection.Open(userInfo);
>>> MgResourceService resourceService =
>>> siteConnection.CreateService(MgServiceType.ResourceService) as
>>> MgResourceService;
>>> MgMap map = new MgMap();
>>> map.Open(resourceService, smgMap);
>>> Resource was not found:
Session:ba7530b4-ffff-ffff-800a-00142260e7d1_en_7F0000010AFC0AFB0AFA//So
>>> leburyTwp.Map
>>> Description: An unhandled exception occurred during the execution of
>> the
>>> current web request. Please review the stack trace for more
>> information
>>> about the error and where it originated in the code.
>>> Exception Details: OSGeo.MapGuide.MgResourceNotFoundException:
>> Resource
>>> was not found:
>>> leburyTwp.Map
>>> Source Error:
>>> Line 28: MgResourceService resourceService =
>>> MgResourceService;
>>> Line 29: MgMap map = new MgMap();
>>> Line 30: map.Open(resourceService, smgMap);
>>> Brian Berdel
>>> p: 215.283.9444
>>> www.mcmtrans.com
>>> Brian Berdel
>>> Applications Development Manager
>>> 425 Commerce Drive, Suite 200
>>> Fort Washington, Pennsylvania 19034
>>> p: 215.283.9444
>>> f: 215.283.9858
>>> <http://www.mcmtrans.com>
>>> New England | Mid-Atlantic | Florida
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/.NET-Fusion-tp16722611s16610p16736574.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> http://themapguyde.blogspot.com
> http://www.linkedin.com/in/jackieng
