[mapguide-users] .NET Fusion
Jason Birch
Jason.Birch at nanaimo.ca
Thu Apr 17 14:19:30 EDT 2008
As far as I know, Fusion works with a .Net install, but you can't write
widgets in .Net unless you re-write the entire widget stack in this
language. This is something that I'd be interested in seeing, but only
from an academic perspective. :)
Brian, how are you integrating .Net into Fusion? With a task pane
application? I wonder if there is a JavaScript function that returns
the map ID?
Jason
-----Original Message-----
Subject: RE: [mapguide-users] .NET Fusion
Mike it actually does because I am able to use the featurereader...I
just cannot open a map. Anyone know how to get the ID?
