[mapguide-users] .NET Fusion
Berdel, Brian brian.berdel at mcmtrans.com
Thu Apr 17 14:31:22 EDT 2008
You are correct about the widgets and .NET, I actually started
converting them a while back, but I haven't been able to dedicate enough
time to it...
And yes I am using the task pane, and the feature reader works fine for
accessing a layer by layer name and session variable, but if I try to
open a map via the name it always tells me it cannot find...One other
question I would have about fusion is how to access the mapframe from
the task pane...
parent.parent.mapframe does not exist.  I saw the documentation about
building a fusion template, but I a haven't really been able to get a
handle on the structure as it relates to the regular AJAX viewer.
Thanks,
Brian  Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Thursday, April 17, 2008 2:20 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] .NET Fusion
As far as I know, Fusion works with a .Net install, but you can't write
widgets in .Net unless you re-write the entire widget stack in this
language.  This is something that I'd be interested in seeing, but only
from an academic perspective. :)
Brian, how are you integrating .Net into Fusion?  With a task pane
application?  I wonder if there is a JavaScript function that returns
the map ID?
Jason
Mike it actually does because I am able to use the featurereader...I
just cannot open a map.  Anyone know how to get the ID?
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
