[mapguide-users] MGOS v2.0 join with other feature source issue
David Nuell nuell at nicholsenvironmental.com
Wed Apr 23 14:43:35 EDT 2008
Hi all -
I have MGOS v2.0 installed on a Win box with server 2003 installed.  I am
also using Autodesk MapGuide Studio v 1.2.0.410 to build the web page.
I have connected my MS Access DB through OSGeo FDO Provider for ODBC and am
attempting to join the tables within that DB with my data layer.
I am successful in connecting a single table to my data and it displays
perfectly fine with the joined attributes.  When I attempt to connect a
second table to the same data, the join works perfectly fine, however the
data (polygons) do not display anymore.  When I remove the second table and
refresh, it displays just fine again.
I have tried different tables, and in different orders however it seems that
only a single table can be joined and be displayed.  Has anyone else run
into this?  Is there a maximum number of joins allowed?
cheers.
View this message in context: http://www.nabble.com/MGOS-v2.0-join-with-other-feature-source-issue-tp16834759p16834759.html
