[mapguide-users] Authentication error at line 199
Kenneth, GEOGRAF A/S
ks at geograf.dk
Wed Apr 23 15:17:37 EDT 2008
You might want to check the authentication settings in IIS.
Try to remove the "Integrated Windows Authentication" setting.
In case it is a browser/firewall issue, try to add the username/password
parameters to the URL:
http://localhost/mapguide2008/mapviewerajax/?WEBLAYOUT=....&USERNAME=Administrator&PASSWORD=admin
That will bypass the authentication header system.
Regards, Kenneth, GEOGRAF A/S
Thomas Brix Lyng skrev:
> Hi
> I'm getting an error with MapGuide Enterprise 2008 I can´t figure:
> åØå"Authentication failed. Please enter a valid username and password.
> Exception occurred in method MgSecurityManager.Authenticate at line
> 199 in file
> c:\build_bond_area\Bond_Nightly\BUILD_41.3\Ent\OS\Server\src\Common\Manager\SecurityManager.cpp
> The error shows in my layout in the taskpanel and no map is showing. I
> can see the map in studio but when I try to view it in my webbrowser
> (IE6 or IE7) i get the error even if I log in with my MapGuide
> administrator password (It works in MapGuide administrator modul PHP).
> Please advice!
> Regards
> Thomas Brix Lyng
> Frederikshavn Municipal Administration
> Denmark
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080423/1fec0156/attachment.html
