[mapguide-users] MGOS v2.0 join with other feature source issue
David Nuell
nuell at nicholsenvironmental.com
Fri Apr 25 09:56:53 EDT 2008
Hi Jackie -
I have tried it both ways.
Attempt 1: In the original polygon layer (parcels), there is an attribute
labelled ObjectID. I attached a table called 'Parcel Information' where
parcels.ObjectID=ParcelInformation.ParcelOID
That join works ok and can be displayed. When I try to connect a second
table 'DeveloperAgreements' to the already joined attribute where
ParcelInformation.ParcelUniqueID=DeveloperAgreements.ParcelUniqueID_FK
It fails to draw the layer. The join can be seen, but no polygons are
shown.
Attempt 2:
I added the attribute 'ParcelUniqueID' to my polygon layer and re-loaded the
SHP to MG Studio. I then attempt to join
Parcels.objectID=ParcelInformation.ParcelOID
This works fine as in the first attempt. When I attempt to connect the
second table with the new ParcelUniqueID in the parcels polygon layer such
as
Parcels.ParcelUniqueID=DeveloperAgreements.ParcelUniqueID_FK
The join works ok, however no polygons are drawn.
Hope the information above can help someone help me out... thanks for the
reply jackie.
Jackie C. Ng wrote:
> With the second table, are you trying to join with the primary (one with
> polygons) or the secondary (the access database) feature class?
> - Jackie
> David Nuell wrote:
>> Hi all -
>> I have MGOS v2.0 installed on a Win box with server 2003 installed. I am
>> also using Autodesk MapGuide Studio v 1.2.0.410 to build the web page.
>> I have connected my MS Access DB through OSGeo FDO Provider for ODBC and
>> am attempting to join the tables within that DB with my data layer.
>> I am successful in connecting a single table to my data and it displays
>> perfectly fine with the joined attributes. When I attempt to connect a
>> second table to the same data, the join works perfectly fine, however the
>> data (polygons) do not display anymore. When I remove the second table
>> and refresh, it displays just fine again.
>> I have tried different tables, and in different orders however it seems
>> that only a single table can be joined and be displayed. Has anyone else
>> run into this? Is there a maximum number of joins allowed?
>> cheers.
View this message in context: http://www.nabble.com/MGOS-v2.0-join-with-other-feature-source-issue-tp16834759p16895767.html
