[mapguide-users] Projection in Google map
Andy Morsell amorsell at spatialgis.com
Fri Apr 25 10:05:40 EDT 2008
Google Map and Google Earth use a latitude longitude WGS84 coordinate system
for displaying their data.  If you are going to integrate your data with it,
you will have to re-project it into that system and then reload the dataset
into MapGuide.  Whatever GIS software you use should have the ability to
transform your data from one coordinate system to another.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of anakando
Sent: Friday, April 25, 2008 12:27 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Projection in Google map
no one?? :,(
anakando wrote:
> hi guys..
> i have a plenty of land base layers and i decided to overlay these
> layer into Google map..so the problem is,my data is in cassini
> projection..so here i like to know how can i convert my data
> projection into projection that supported by Google map?what is the
> first step should i do? i really appreciated your help. thanks in
> advanced _______________________________________________
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/Projection-in-Google-map-tp16872352p16892095.html
