[mapguide-users] Out of Memory error problem
nclayton
nclayton at gmail.com
Mon Apr 28 08:48:27 EDT 2008
Hi all,
I have been having problems with MGOS 2.0 crashing on me to the point that i
was using a script to restart the service every 30 minutes.
I resolved part of the problem by changing how one of my layers was
rendered.
But, after running without a restart for about 2 days I got the following
errors:
<2008-04-25T11:32:56> Anonymous
Error: An exception occurred in FDO component.
'FdoFgfLinearRing::Reset': Cannot execute function due to invalid
value for the input parameter(s) 'positions'.
StackTrace:
- MgRenderingServiceHandler.ProcessOperation line 83 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
- MgOpQueryFeatures.Execute line 125 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
- MgServerRenderingService.QueryFeatures line 647 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\ServerRenderingService.cpp
- MgServerRenderingService.RenderForSelection line 1252 file
- MgServerSelectFeatures.SelectFeatures line 249 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
'FdoFgfLinearRing::Reset': Cannot execute function due to invalid value for
<2008-04-25T11:57:23> Anonymous
Error: Failed to stylize layer: aerial
Out of memory.
bad allocation
StackTrace:
- MgMappingUtil.StylizeLayers line 776 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\mapping\MappingUtil.cpp
Out of memory.
bad allocation
<2008-04-25T12:21:39> Anonymous
Error: Out of memory.
bad allocation
StackTrace:
- MgOpRenderDynamicOverlay.Execute line 109 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\OpRenderDynamicOverlay.cpp
- MgServerRenderingService.RenderDynamicOverlay line 305 file
Out of memory.
bad allocation
Thank you for any help that can be provided.
View this message in context: http://www.nabble.com/Out-of-Memory-error-problem-tp16938026p16938026.html
