[mapguide-users] Out of Memory error problem
Zac Spitzer zac.spitzer at gmail.com
Mon Apr 28 08:55:48 EDT 2008
i have been having had similiar problems
can you share what you did to the layer rendering? tiled or untiled?
z
On Mon, Apr 28, 2008 at 10:48 PM, nclayton <nclayton at gmail.com> wrote:
>  Hi all,
>  I have been having problems with MGOS 2.0 crashing on me to the point that i
>  was using a script to restart the service every 30 minutes.
>  I resolved part of the problem by changing how one of my layers was
>  rendered.
>  But, after running without a restart for about 2 days I got the following
>  errors:
>  <2008-04-25T11:32:56>                   Anonymous
>   Error: An exception occurred in FDO component.
>         'FdoFgfLinearRing::Reset': Cannot execute function due to invalid
>  value for the input parameter(s) 'positions'.
>   StackTrace:
>   - MgRenderingServiceHandler.ProcessOperation line 83 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
>   - MgOpQueryFeatures.Execute line 125 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
>   - MgServerRenderingService.QueryFeatures line 647 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\ServerRenderingService.cpp
>   - MgServerRenderingService.RenderForSelection line 1252 file
>   - MgServerSelectFeatures.SelectFeatures line 249 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
>  'FdoFgfLinearRing::Reset': Cannot execute function due to invalid value for
>  <2008-04-25T11:57:23>                   Anonymous
>   Error: Failed to stylize layer: aerial
>         Out of memory.
>         bad allocation
>   StackTrace:
>   - MgMappingUtil.StylizeLayers line 776 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\mapping\MappingUtil.cpp
>  Out of memory.
>  bad allocation
>  <2008-04-25T12:21:39>                   Anonymous
>   Error: Out of memory.
>         bad allocation
>   StackTrace:
>   - MgOpRenderDynamicOverlay.Execute line 109 file
>  d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\OpRenderDynamicOverlay.cpp
>   - MgServerRenderingService.RenderDynamicOverlay line 305 file
>  Out of memory.
>  bad allocation
>  Thank you for any help that can be provided.
>  View this message in context: http://www.nabble.com/Out-of-Memory-error-problem-tp16938026p16938026.html
>  Sent from the MapGuide Users mailing list archive at Nabble.com.
>  _______________________________________________
>  mapguide-users mailing list
>  mapguide-users at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/mapguide-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
