[mapguide-users] Oracle Points and King Oracle Provider
mauro1970 mgvillablanca at yahoo.com
Tue Apr 29 15:16:42 EDT 2008
I don't have an answer to your question ould you be so kind to post the code
you used for querying the spatial data in Oracle?
max_samart wrote:
> Hi All,
>            I tried to use the king oracle 0.7.3 for getting the point data
> from Oracle Database 10.1.0.3 ,I tried using FDO Class table and able to
> view those points in the mapguide as well as select those points. After
> that i tried why i don't create a Geometry Point using the Lat,Lon Columns
> in the Oracle Database ,i succesfully able to create the New Geometry
> Column as well as also created spatial index and Promary key for Point
> Geometry Type. I have also set SDO Metadata and Oracle Srid as 8192.
> Finally i able to connect to the oracle database as well as able to create
> point layer using MapGuide Studio2008, but once i want to select the Point
> , i unable to select the point as well view the properties.I am using MGOS
> 1.2.0. Can anybody help me out what i am messing up !
> Thks
> Max
> ____________________________________________________________________________________
> Looking for last minute shopping deals?
> Find them fast with Yahoo! Search.
> http://tools.search.yahoo.com/newsearch/category.php?category=shopping
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Oracle-Points-and-King-Oracle-Provider-tp15845451p16968015.html
