[mapguide-users] Out of Memory error problem
nclayton
nclayton at gmail.com
Wed Apr 30 08:25:02 EDT 2008
After setting the connection times settings back to their original 60 and 120
values, the server has been stable for 18 hours, but the memory usage is
sitting at 488,148K and there probably aren't any connections established
currently. In all of the examples that I have seen, only one map is being
served. Is MGOS capable of serving many different maps to many people at a
time out of the box? Are there any other tweaks or recommendations for
improving memory use?
Thanks again.
nclayton wrote:
> I've modified the serverconfig.ini connection timeout settings so am going
> to watch it for a bit to see if that helps. The problem with my situation
> is that it's not a particular site causing the problem...it's basically
> whichever site just happens to be the one that tips the memory too far.
> It will be a bit before we start getting hits, so I will post how things
> go later.
> Thank you for your input.
> zspitzer wrote:
>> one option you could try is tweaking the settings under
>> FeatureServiceProperties in ServerConfig.ini
>> with shorter timeouts for the connections
>> can you file a bug for the Shape16 vs Shape31 issue in trac?
>> what type of feature sources are you using? What size of area are your
>> maps and at what scale?
>> Due to the nature of mapping data it is hard to provide test cases for
>> developers to debug, the holy grail is being able
>> to provide a mgp file which exhibits a specific issue.
>> That said, I have a test case uploaded against the samples which falls
>> over under load with the sample data on windows
>> overall, stability is rather problematic at the moment with mg 2.0,
>> some of the demo sites are down at times
>> http://demo01.dmsolutions.ca/mapguide/fusion/templates/mapguide/slate/
>> (busted)
>> http://data.mapguide.com/mapguide/phpviewersample/ajaxtiledviewersample.php
>> (works, might be mge tho)
>> http://mapguidebeta.osgeo.org/mapguide/fusion/templates/mapguide/slate/index.html
>> (working)
>> z
>> On Tue, Apr 29, 2008 at 2:19 AM, nclayton <nclayton at gmail.com> wrote:
>>> I'm watching my mgserver.exe in task manager, and it is currently up to
>>> 830MB+.
>>> My OS is Windows 2003 Standard and I am using MGOS 2.0
>>> I am hosting multiple maps. Currently there are 4 but once I get these
>>> wrinkles ironed out there will be 20+.
>>> Are there steps that I can perform to reduce the amount of memory being
>>> used? Such as programatically close connections or something? Right now
>>> the
>>> service is set to restart every 4 hours...which should remove the used
>>> memory, but at the price of losing user sessions which is what I'm
>>> trying to
>>> avoid.
>>> nclayton wrote:
>>> > Hi all,
>>> > I have been having problems with MGOS 2.0 crashing on me to the point
>>> that
>>> > i was using a script to restart the service every 30 minutes.
>>> > I resolved part of the problem by changing how one of my layers was
>>> > rendered.
>>> > But, after running without a restart for about 2 days I got the
>>> following
>>> > errors:
>>> > <2008-04-25T11:32:56> Anonymous
>>> > Error: An exception occurred in FDO component.
>>> > 'FdoFgfLinearRing::Reset': Cannot execute function due to
>>> invalid
>>> > value for the input parameter(s) 'positions'.
>>> > StackTrace:
>>> > - MgRenderingServiceHandler.ProcessOperation line 83 file
>>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
>>> > - MgOpQueryFeatures.Execute line 125 file
>>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
>>> > - MgServerRenderingService.QueryFeatures line 647 file
>>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\ServerRenderingService.cpp
>>> > - MgServerRenderingService.RenderForSelection line 1252 file
>>> > - MgServerSelectFeatures.SelectFeatures line 249 file
>>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\feature\ServerSelectFeatures.cpp
>>> > 'FdoFgfLinearRing::Reset': Cannot execute function due to invalid
>>> value
>>> > <2008-04-25T11:57:23> Anonymous
>>> > Error: Failed to stylize layer: aerial
>>> > Out of memory.
>>> > bad allocation
>>> > StackTrace:
>>> > - MgMappingUtil.StylizeLayers line 776 file
>>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\mapping\MappingUtil.cpp
>>> > Out of memory.
>>> > bad allocation
>>> > <2008-04-25T12:21:39> Anonymous
>>> > Error: Out of memory.
>>> > bad allocation
>>> > StackTrace:
>>> > - MgOpRenderDynamicOverlay.Execute line 109 file
>>> d:\buildforgeprojects\mapguide_open_source_v2.0\build_23.8\mgdev\server\src\services\rendering\OpRenderDynamicOverlay.cpp
>>> > - MgServerRenderingService.RenderDynamicOverlay line 305 file
>>> > Out of memory.
>>> > bad allocation
>>> > Thank you for any help that can be provided.
>>> View this message in context:
>>> http://www.nabble.com/Out-of-Memory-error-problem-tp16938026p16942501.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
View this message in context: http://www.nabble.com/Out-of-Memory-error-problem-tp16938026p16981307.html
