[mapguide-users] Mapguide 2.0.1.2716 build problem
isca mapguide2007 at gmail.com
Fri Aug 1 07:48:37 EDT 2008
I am having problems building MapGuide on windows too, as it seems that some
of the filenames have been truncated for some reason ... maybe the package
is corrupt ?
mike-607 wrote:
> I have a Debian linux machine running the latest stable release of all
> debian packages including libraries, compilers, etc to the best of my
> knowledge (as a side note I was able to successfully compile FDO).  I have
> downloaded the source for mapguide version 2.0.1.2716 and am now trying to
> run the build_oem.sh script.  When I do the process returns with numerous
> errors as well as a warning about the header file atomic.h.  I have
> included the complete output here for your review; please send any
> suggestions you may have as I'm not sure how to fix this.
> MapGuide Open Source build script for OEM components
> OEM Build Initialization ............................
> Oem Libraries will be installed at: /usr/local/mapguideopensource
> /usr/local/src/mapguide-2.0.1/Oem /usr/local/src/mapguide-2.0.1
> ace: Initialization...........................
> ace: Configure/Build ...........................
> /usr/local/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers
> /usr/local/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace
> make[1]: Entering directory
> `/usr/local/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace'
> Makefile:
> /usr/local/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace/Makefile.ace
> make[1]: Leaving directory
> make -f Makefile.dirs SUBDIR_TARGET=all RMCast.subdir
> make[2]: Entering directory
> make -f Makefile -C RMCast all
> make[3]: Entering directory
> `/usr/local/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace/RMCast'
> make[3]: Nothing to be done for `all'.
> make[3]: Leaving directory
> make[2]: Leaving directory
> Makefile:
> /usr/local/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace/Makefile.dirs
> ace: Build Successful ..........................
> dwfcore: Initialization...........................
> /usr/local/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore
> dwfcore: Configure/Build ...........................
> /usr/local/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for a thread-safe mkdir -p... /bin/mkdir -p
> checking for gawk... no
> checking for mawk... mawk
> checking whether make sets $(MAKE)... yes
> checking for g++... g++
> checking for C++ compiler default output file name... a.out
> checking whether the C++ compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking for style of include used by make... GNU
> checking dependency style of g++... gcc3
> checking build system type... i686-pc-linux-gnu
> checking host system type... i686-pc-linux-gnu
> checking for gcc... gcc
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ISO C89... none needed
> checking dependency style of gcc... gcc3
> checking for a sed that does not truncate output... /bin/sed
> checking for grep that handles long lines and -e... /bin/grep
> checking for egrep... /bin/grep -E
> checking for ld used by gcc... /usr/bin/ld
> checking if the linker (/usr/bin/ld) is GNU ld... yes
> checking for /usr/bin/ld option to reload object files... -r
> checking for BSD-compatible nm... /usr/bin/nm -B
> checking whether ln -s works... yes
> checking how to recognise dependent libraries... pass_all
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking dlfcn.h usability... yes
> checking dlfcn.h presence... yes
> checking for dlfcn.h... yes
> checking how to run the C++ preprocessor... g++ -E
> checking for g77... no
> checking for xlf... no
> checking for f77... no
> checking for frt... no
> checking for pgf77... no
> checking for cf77... no
> checking for fort77... no
> checking for fl32... no
> checking for af77... no
> checking for xlf90... no
> checking for f90... no
> checking for pgf90... no
> checking for pghpf... no
> checking for epcf90... no
> checking for gfortran... no
> checking for g95... no
> checking for xlf95... no
> checking for f95... no
> checking for fort... no
> checking for ifort... no
> checking for ifc... no
> checking for efc... no
> checking for pgf95... no
> checking for lf95... no
> checking for ftn... no
> checking whether we are using the GNU Fortran 77 compiler... no
> checking whether  accepts -g... no
> checking the maximum length of command line arguments... 32768
> checking command to parse /usr/bin/nm -B output from gcc object... ok
> checking for objdir... .libs
> checking for ar... ar
> checking for ranlib... ranlib
> checking for strip... strip
> checking if gcc supports -fno-rtti -fno-exceptions... no
> checking for gcc option to produce PIC... -fPIC
> checking if gcc PIC flag -fPIC works... yes
> checking if gcc static flag -static works... yes
> checking if gcc supports -c -o file.o... yes
> checking whether the gcc linker (/usr/bin/ld) supports shared libraries...
> yes
> checking whether -lc should be explicitly linked in... no
> checking dynamic linker characteristics... GNU/Linux ld.so
> checking how to hardcode library paths into programs... immediate
> checking whether stripping libraries is possible... yes
> checking if libtool supports shared libraries... yes
> checking whether to build shared libraries... yes
> checking whether to build static libraries... yes
> configure: creating libtool
> appending configuration tag "CXX" to libtool
> checking for ld used by g++... /usr/bin/ld
> checking whether the g++ linker (/usr/bin/ld) supports shared libraries...
> yes
> checking for g++ option to produce PIC... -fPIC
> checking if g++ PIC flag -fPIC works... yes
> checking if g++ static flag -static works... yes
> checking if g++ supports -c -o file.o... yes
> yes
> appending configuration tag "F77" to libtool
> checking asm/atomic.h usability... no
> checking asm/atomic.h presence... yes
> configure: WARNING: asm/atomic.h: present but cannot be compiled
> configure: WARNING: asm/atomic.h:     check for missing prerequisite
> headers?
> configure: WARNING: asm/atomic.h: see the Autoconf documentation
> configure: WARNING: asm/atomic.h:     section "Present But Cannot Be
> Compiled"
> configure: WARNING: asm/atomic.h: proceeding with the preprocessor's
> result
> configure: WARNING: asm/atomic.h: in the future, the compiler will take
> precedence
> configure: WARNING:     ## ------------------------------------------ ##
> configure: WARNING:     ## Report this to http://www.autodesk.com/dwf ##
> checking for asm/atomic.h... yes
> checking alsa/iatomic.h usability... no
> checking alsa/iatomic.h presence... no
> checking for alsa/iatomic.h... no
> checking netinet/ether.h usability... yes
> checking netinet/ether.h presence... yes
> checking for netinet/ether.h... yes
> configure: asm/atomic.h available but required operations are missing
> configure: alsa/iatomic.h available but required operations are missing
> checking for pthread_create in -lpthread... yes
> checking for uuid_generate in -luuid... no
> checking for inflate in -lz... yes
> configure: Using optimized configuration
> configure: gcc 3.2.x requires less strict compiler flags. Please pay
> attention to warnings!
> configure: creating ./config.status
> config.status: creating Makefile
> config.status: creating ansi/Makefile
> config.status: creating mac/Makefile
> config.status: creating zip/Makefile
> config.status: creating zlib/Makefile
> config.status: creating x86/Makefile
> config.status: creating config.h
> config.status: config.h is unchanged
> config.status: executing depfiles commands
> make  all-recursive
> `/usr/local/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore'
> Making all in ansi
> `/usr/local/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore/ansi'
> make[2]: Nothing to be done for `all'.
> Making all in mac
> `/usr/local/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore/mac'
> Making all in x86
> `/usr/local/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore/x86'
> /bin/sh ../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H  -I../..
>   -g0 -O2 -pipe -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo
> -Wsign-compare -Wundef -Wstrict-prototypes -fforce-addr -finline-functions
> -ffast-math -fno-strict-aliasing -MT Core.lo -MD -MP -MF .deps/Core.Tpo -c
> -o Core.lo Core.cpp
>  g++ -DHAVE_CONFIG_H -I../.. -g0 -O2 -pipe -Wall -Wno-long-long
> -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes
> -fforce-addr -finline-functions -ffast-math -fno-strict-aliasing -MT
> Core.lo -MD -MP -MF .deps/Core.Tpo -c Core.cpp  -fPIC -DPIC -o
> .libs/Core.o
> cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
> Ada/C/ObjC but not for C++
> /usr/include/asm-i486/bitops.h:244: error: expected initializer before
> 'int'
> /usr/include/linux/bitops.h: In function 'long unsigned int
> hweight_long(long unsigned int)':
> /usr/include/linux/bitops.h:31: error: 'hweight32' was not declared in
> this
> scope
> /usr/include/linux/bitops.h:31: error: 'hweight64' was not declared in
> this
> scope
> /usr/include/asm-i486/system.h: At global scope:
> /usr/include/asm-i486/system.h:273: error: expected ',' or '...' before
> 'new'
> /usr/include/asm-i486/system.h: In function 'long unsigned int
> __cmpxchg(volatile void*, long unsigned int, long unsigned int)':
> /usr/include/asm-i486/system.h:276: error: 'size' was not declared in this
> scope
> /usr/include/asm-i486/system.h:280: error: expected type-specifier before
> ')' token
> /usr/include/asm-i486/system.h:286: error: expected type-specifier before
> ')' token
> /usr/include/asm-i486/system.h:292: error: expected type-specifier before
> ')' token
> /usr/include/asm-i486/system.h:306: error: 'u8' has not been declared
> /usr/include/asm-i486/system.h:307: error: 'u16' has not been declared
> /usr/include/asm-i486/system.h:308: error: 'u32' has not been declared
> /usr/include/asm-i486/system.h:311: error: expected ',' or '...' before
> 'new'
> cmpxchg_386(volatile void*, long unsigned int, long unsigned int)':
> /usr/include/asm-i486/system.h:313: error: 'size' was not declared in this
> scope
> /usr/include/asm-i486/system.h:315: error: expected type-specifier before
> ')' token
> /usr/include/asm-i486/system.h:315: error: invalid conversion from 'int*'
> to 'int'
> /usr/include/asm-i486/system.h:315: error:   initializing argument 3 of
> 'long unsigned int cmpxchg_386_u8(volatile void*, int, int)'
> /usr/include/asm-i486/system.h:317: error: expected type-specifier before
> ')' token
> /usr/include/asm-i486/system.h:317: error: invalid conversion from 'int*'
> to 'int'
> /usr/include/asm-i486/system.h:317: error:   initializing argument 3 of
> 'long unsigned int cmpxchg_386_u16(volatile void*, int, int)'
> /usr/include/asm-i486/system.h:319: error: expected type-specifier before
> ')' token
> /usr/include/asm-i486/system.h:319: error: invalid conversion from 'int*'
> to 'int'
> /usr/include/asm-i486/system.h:319: error:   initializing argument 3 of
> 'long unsigned int cmpxchg_386_u32(volatile void*, int, int)'
> /usr/include/linux/bitmap.h: At global scope:
> /usr/include/linux/bitmap.h:116: error: expected ',' or '...' before 'new'
> /usr/include/linux/bitmap.h:118: error: expected ',' or '...' before 'new'
> /usr/include/linux/bitmap.h: In function 'void bitmap_zero(long unsigned
> int*, int)':
> /usr/include/linux/bitmap.h:131: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h:134: error: 'BITS_TO_LONGS' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'void bitmap_fill(long unsigned
> int*, int)':
> /usr/include/linux/bitmap.h:141: error: 'BITS_TO_LONGS' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h:146: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'void bitmap_copy(long unsigned
> int*, const long unsigned int*, int)':
> /usr/include/linux/bitmap.h:152: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h:155: error: 'BITS_TO_LONGS' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'void bitmap_and(long unsigned
> int*, const long unsigned int*, const long unsigned int*, int)':
> /usr/include/linux/bitmap.h:163: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'void bitmap_or(long unsigned
> /usr/include/linux/bitmap.h:172: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'void bitmap_xor(long unsigned
> /usr/include/linux/bitmap.h:181: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'void bitmap_andnot(long unsigned
> /usr/include/linux/bitmap.h:190: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'void bitmap_complement(long
> /usr/include/linux/bitmap.h:199: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'int bitmap_equal(const long
> /usr/include/linux/bitmap.h:208: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'int bitmap_intersects(const long
> /usr/include/linux/bitmap.h:217: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'int bitmap_subset(const long
> /usr/include/linux/bitmap.h:226: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'int bitmap_empty(const long
> /usr/include/linux/bitmap.h:234: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'int bitmap_full(const long
> /usr/include/linux/bitmap.h:242: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'int bitmap_weight(const long
> /usr/include/linux/bitmap.h:250: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'void bitmap_shift_right(long
> unsigned int*, const long unsigned int*, int, int)':
> /usr/include/linux/bitmap.h:258: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/bitmap.h: In function 'void bitmap_shift_left(long
> /usr/include/linux/bitmap.h:267: error: 'BITS_PER_LONG' was not declared
> in
> this scope
> /usr/include/linux/cpumask.h: At global scope:
> /usr/include/linux/cpumask.h:88: error: 'bits' has not been declared
> /usr/include/linux/cpumask.h:88: error: expected identifier before numeric
> constant
> /usr/include/linux/cpumask.h:88: error: expected ',' or '...' before
> numeric constant
> /usr/include/linux/cpumask.h: In function 'void __cpu_set(int, volatile
> cpumask_t*)':
> /usr/include/linux/cpumask.h:94: error: 'volatile struct cpumask_t' has no
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'void __cpu_clear(int, volatile
> cpumask_t*)':
> /usr/include/linux/cpumask.h:100: error: 'volatile struct cpumask_t' has
> no
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'void __cpus_setall(cpumask_t*,
> int)':
> /usr/include/linux/cpumask.h:106: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h: In function 'void __cpus_clear(cpumask_t*,
> int)':
> /usr/include/linux/cpumask.h:112: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h: In function 'int __cpu_test_and_set(int,
> cpumask_t*)':
> /usr/include/linux/cpumask.h:121: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h: In function 'void __cpus_and(cpumask_t*,
> const cpumask_t*, const cpumask_t*, int)':
> /usr/include/linux/cpumask.h:128: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h:128: error: 'const struct cpumask_t' has no
> member named 'bits'
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'void __cpus_or(cpumask_t*,
> const
> /usr/include/linux/cpumask.h:135: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h:135: error: 'const struct cpumask_t' has no
> member named 'bits'
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'void __cpus_xor(cpumask_t*,
> /usr/include/linux/cpumask.h:142: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h:142: error: 'const struct cpumask_t' has no
> member named 'bits'
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'void __cpus_andnot(cpumask_t*,
> /usr/include/linux/cpumask.h:150: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h:150: error: 'const struct cpumask_t' has no
> member named 'bits'
> member named 'bits'
> __cpus_complement(cpumask_t*, const cpumask_t*, int)':
> /usr/include/linux/cpumask.h:157: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h:157: error: 'const struct cpumask_t' has no
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'int __cpus_equal(const
> /usr/include/linux/cpumask.h:164: error: 'const struct cpumask_t' has no
> member named 'bits'
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'int __cpus_intersects(const
> /usr/include/linux/cpumask.h:171: error: 'const struct cpumask_t' has no
> member named 'bits'
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'int __cpus_subset(const
> /usr/include/linux/cpumask.h:178: error: 'const struct cpumask_t' has no
> member named 'bits'
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'int __cpus_empty(const
> cpumask_t*, int)':
> /usr/include/linux/cpumask.h:184: error: 'const struct cpumask_t' has no
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'int __cpus_full(const
> cpumask_t*, int)':
> /usr/include/linux/cpumask.h:190: error: 'const struct cpumask_t' has no
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'int __cpus_weight(const
> cpumask_t*, int)':
> /usr/include/linux/cpumask.h:196: error: 'const struct cpumask_t' has no
> member named 'bits'
> __cpus_shift_right(cpumask_t*, const cpumask_t*, int, int)':
> /usr/include/linux/cpumask.h:204: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h:204: error: 'const struct cpumask_t' has no
> member named 'bits'
> __cpus_shift_left(cpumask_t*, const cpumask_t*, int, int)':
> /usr/include/linux/cpumask.h:212: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h:212: error: 'const struct cpumask_t' has no
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'int __cpumask_scnprintf(char*,
> int, const cpumask_t*, int)':
> /usr/include/linux/cpumask.h:273: error: 'const struct cpumask_t' has no
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'int __cpumask_parse(const
> char*,
> int, cpumask_t*, int)':
> /usr/include/linux/cpumask.h:281: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h: In function 'int __cpulist_scnprintf(char*,
> /usr/include/linux/cpumask.h:289: error: 'const struct cpumask_t' has no
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'int __cpulist_parse(const
> char*,
> cpumask_t*, int)':
> /usr/include/linux/cpumask.h:295: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h: In function 'int __cpu_remap(int, const
> /usr/include/linux/cpumask.h:303: error: 'const struct cpumask_t' has no
> member named 'bits'
> member named 'bits'
> /usr/include/linux/cpumask.h: In function 'void __cpus_remap(cpumask_t*,
> const cpumask_t*, const cpumask_t*, const cpumask_t*, int)':
> /usr/include/linux/cpumask.h:311: error: 'struct cpumask_t' has no member
> named 'bits'
> /usr/include/linux/cpumask.h:311: error: 'const struct cpumask_t' has no
> member named 'bits'
> member named 'bits'
> member named 'bits'
> /usr/include/asm-i486/processor.h: At global scope:
> /usr/include/asm-i486/processor.h:80: error: 'CONFIG_X86_L1_CACHE_SHIFT'
> was not declared in this scope
> /usr/include/asm-i486/processor.h:80: error: requested alignment is not a
> constant
> /usr/include/asm-i486/processor.h: In function 'void set_in_cr4(long
> unsigned int)':
> /usr/include/asm-i486/processor.h:246: error: 'read_cr4' was not declared
> in this scope
> /usr/include/asm-i486/processor.h:248: error: 'write_cr4' was not declared
> in this scope
> /usr/include/asm-i486/processor.h: In function 'void clear_in_cr4(long
> unsigned int)':
> /usr/include/asm-i486/processor.h:255: error: 'read_cr4' was not declared
> in this scope
> /usr/include/asm-i486/processor.h:257: error: 'write_cr4' was not declared
> in this scope
> load_esp0(tss_struct*,
> thread_struct*)':
> /usr/include/asm-i486/processor.h:500: error: 'unlikely' was not declared
> in this scope
> make[2]: *** [Core.lo] Error 1
> make[1]: *** [all-recursive] Error 1
> make: *** [all] Error 2
> DWFCORE 1.0: Error build failed (0).................
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Mapguide-2.0.1.2716-build-problem-tp18763921p18772780.html
