[mapguide-users] Mapguide 2.0.1.2716 build problem
Zac Spitzer zac.spitzer at gmail.com
Fri Aug 1 22:08:19 EDT 2008
Try using subversion instead, that way you can easily pick up bug fixes as well
On 8/1/08, isca <mapguide2007 at gmail.com> wrote:
> I am having problems building MapGuide on windows too, as it seems that some
> of the filenames have been truncated for some reason ... maybe the package
> is corrupt ?
> mike-607 wrote:
>> I have a Debian linux machine running the latest stable release of all
>> debian packages including libraries, compilers, etc to the best of my
>> knowledge (as a side note I was able to successfully compile FDO).  I have
>> downloaded the source for mapguide version 2.0.1.2716 and am now trying to
>> run the build_oem.sh script.  When I do the process returns with numerous
>> errors as well as a warning about the header file atomic.h.  I have
>> included the complete output here for your review; please send any
>> suggestions you may have as I'm not sure how to fix this.
>> MapGuide Open Source build script for OEM components
>> OEM Build Initialization ............................
>> Oem Libraries will be installed at: /usr/local/mapguideopensource
>> /usr/local/src/mapguide-2.0.1/Oem /usr/local/src/mapguide-2.0.1
>> ace: Initialization...........................
>> ace: Configure/Build ...........................
>> /usr/local/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers
>> /usr/local/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace
>> make[1]: Entering directory
>> `/usr/local/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace'
>> Makefile:
>> /usr/local/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace/Makefile.ace
>> make[1]: Leaving directory
>> make -f Makefile.dirs SUBDIR_TARGET=all RMCast.subdir
>> make[2]: Entering directory
>> make -f Makefile -C RMCast all
>> make[3]: Entering directory
>> `/usr/local/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace/RMCast'
>> make[3]: Nothing to be done for `all'.
>> make[3]: Leaving directory
>> make[2]: Leaving directory
>> Makefile:
>> /usr/local/src/mapguide-2.0.1/Oem/ACE/ACE_wrappers/ace/Makefile.dirs
>> ace: Build Successful ..........................
>> dwfcore: Initialization...........................
>> /usr/local/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore
>> dwfcore: Configure/Build ...........................
>> /usr/local/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore
>> checking for a BSD-compatible install... /usr/bin/install -c
>> checking whether build environment is sane... yes
>> checking for a thread-safe mkdir -p... /bin/mkdir -p
>> checking for gawk... no
>> checking for mawk... mawk
>> checking whether make sets $(MAKE)... yes
>> checking for g++... g++
>> checking for C++ compiler default output file name... a.out
>> checking whether the C++ compiler works... yes
>> checking whether we are cross compiling... no
>> checking for suffix of executables...
>> checking for suffix of object files... o
>> checking whether we are using the GNU C++ compiler... yes
>> checking whether g++ accepts -g... yes
>> checking for style of include used by make... GNU
>> checking dependency style of g++... gcc3
>> checking build system type... i686-pc-linux-gnu
>> checking host system type... i686-pc-linux-gnu
>> checking for gcc... gcc
>> checking whether we are using the GNU C compiler... yes
>> checking whether gcc accepts -g... yes
>> checking for gcc option to accept ISO C89... none needed
>> checking dependency style of gcc... gcc3
>> checking for a sed that does not truncate output... /bin/sed
>> checking for grep that handles long lines and -e... /bin/grep
>> checking for egrep... /bin/grep -E
>> checking for ld used by gcc... /usr/bin/ld
>> checking if the linker (/usr/bin/ld) is GNU ld... yes
>> checking for /usr/bin/ld option to reload object files... -r
>> checking for BSD-compatible nm... /usr/bin/nm -B
>> checking whether ln -s works... yes
>> checking how to recognise dependent libraries... pass_all
>> checking how to run the C preprocessor... gcc -E
>> checking for ANSI C header files... yes
>> checking for sys/types.h... yes
>> checking for sys/stat.h... yes
>> checking for stdlib.h... yes
>> checking for string.h... yes
>> checking for memory.h... yes
>> checking for strings.h... yes
>> checking for inttypes.h... yes
>> checking for stdint.h... yes
>> checking for unistd.h... yes
>> checking dlfcn.h usability... yes
>> checking dlfcn.h presence... yes
>> checking for dlfcn.h... yes
>> checking how to run the C++ preprocessor... g++ -E
>> checking for g77... no
>> checking for xlf... no
>> checking for f77... no
>> checking for frt... no
>> checking for pgf77... no
>> checking for cf77... no
>> checking for fort77... no
>> checking for fl32... no
>> checking for af77... no
>> checking for xlf90... no
>> checking for f90... no
>> checking for pgf90... no
>> checking for pghpf... no
>> checking for epcf90... no
>> checking for gfortran... no
>> checking for g95... no
>> checking for xlf95... no
>> checking for f95... no
>> checking for fort... no
>> checking for ifort... no
>> checking for ifc... no
>> checking for efc... no
>> checking for pgf95... no
>> checking for lf95... no
>> checking for ftn... no
>> checking whether we are using the GNU Fortran 77 compiler... no
>> checking whether  accepts -g... no
>> checking the maximum length of command line arguments... 32768
>> checking command to parse /usr/bin/nm -B output from gcc object... ok
>> checking for objdir... .libs
>> checking for ar... ar
>> checking for ranlib... ranlib
>> checking for strip... strip
>> checking if gcc supports -fno-rtti -fno-exceptions... no
>> checking for gcc option to produce PIC... -fPIC
>> checking if gcc PIC flag -fPIC works... yes
>> checking if gcc static flag -static works... yes
>> checking if gcc supports -c -o file.o... yes
>> checking whether the gcc linker (/usr/bin/ld) supports shared libraries...
>> yes
>> checking whether -lc should be explicitly linked in... no
>> checking dynamic linker characteristics... GNU/Linux ld.so
>> checking how to hardcode library paths into programs... immediate
>> checking whether stripping libraries is possible... yes
>> checking if libtool supports shared libraries... yes
>> checking whether to build shared libraries... yes
>> checking whether to build static libraries... yes
>> configure: creating libtool
>> appending configuration tag "CXX" to libtool
>> checking for ld used by g++... /usr/bin/ld
>> checking whether the g++ linker (/usr/bin/ld) supports shared libraries...
>> yes
>> checking for g++ option to produce PIC... -fPIC
>> checking if g++ PIC flag -fPIC works... yes
>> checking if g++ static flag -static works... yes
>> checking if g++ supports -c -o file.o... yes
>> yes
>> appending configuration tag "F77" to libtool
>> checking asm/atomic.h usability... no
>> checking asm/atomic.h presence... yes
>> configure: WARNING: asm/atomic.h: present but cannot be compiled
>> configure: WARNING: asm/atomic.h:     check for missing prerequisite
>> headers?
>> configure: WARNING: asm/atomic.h: see the Autoconf documentation
>> configure: WARNING: asm/atomic.h:     section "Present But Cannot Be
>> Compiled"
>> configure: WARNING: asm/atomic.h: proceeding with the preprocessor's
>> result
>> configure: WARNING: asm/atomic.h: in the future, the compiler will take
>> precedence
>> configure: WARNING:     ## ------------------------------------------ ##
>> configure: WARNING:     ## Report this to http://www.autodesk.com/dwf ##
>> checking for asm/atomic.h... yes
>> checking alsa/iatomic.h usability... no
>> checking alsa/iatomic.h presence... no
>> checking for alsa/iatomic.h... no
>> checking netinet/ether.h usability... yes
>> checking netinet/ether.h presence... yes
>> checking for netinet/ether.h... yes
>> configure: asm/atomic.h available but required operations are missing
>> configure: alsa/iatomic.h available but required operations are missing
>> checking for pthread_create in -lpthread... yes
>> checking for uuid_generate in -luuid... no
>> checking for inflate in -lz... yes
>> configure: Using optimized configuration
>> configure: gcc 3.2.x requires less strict compiler flags. Please pay
>> attention to warnings!
>> configure: creating ./config.status
>> config.status: creating Makefile
>> config.status: creating ansi/Makefile
>> config.status: creating mac/Makefile
>> config.status: creating zip/Makefile
>> config.status: creating zlib/Makefile
>> config.status: creating x86/Makefile
>> config.status: creating config.h
>> config.status: config.h is unchanged
>> config.status: executing depfiles commands
>> make  all-recursive
>> `/usr/local/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore'
>> Making all in ansi
>> `/usr/local/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore/ansi'
>> make[2]: Nothing to be done for `all'.
>> Making all in mac
>> `/usr/local/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore/mac'
>> Making all in x86
>> `/usr/local/src/mapguide-2.0.1/Oem/DWFTK7.1/develop/global/src/dwfcore/x86'
>> /bin/sh ../libtool --tag=CXX   --mode=compile g++ -DHAVE_CONFIG_H  -I../..
>>   -g0 -O2 -pipe -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo
>> -Wsign-compare -Wundef -Wstrict-prototypes -fforce-addr -finline-functions
>> -ffast-math -fno-strict-aliasing -MT Core.lo -MD -MP -MF .deps/Core.Tpo -c
>> -o Core.lo Core.cpp
>>  g++ -DHAVE_CONFIG_H -I../.. -g0 -O2 -pipe -Wall -Wno-long-long
>> -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes
>> -fforce-addr -finline-functions -ffast-math -fno-strict-aliasing -MT
>> Core.lo -MD -MP -MF .deps/Core.Tpo -c Core.cpp  -fPIC -DPIC -o
>> .libs/Core.o
>> cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
>> Ada/C/ObjC but not for C++
>> /usr/include/asm-i486/bitops.h:244: error: expected initializer before
>> 'int'
>> /usr/include/linux/bitops.h: In function 'long unsigned int
>> hweight_long(long unsigned int)':
>> /usr/include/linux/bitops.h:31: error: 'hweight32' was not declared in
>> this
>> scope
>> /usr/include/linux/bitops.h:31: error: 'hweight64' was not declared in
>> this
>> scope
>> /usr/include/asm-i486/system.h: At global scope:
>> /usr/include/asm-i486/system.h:273: error: expected ',' or '...' before
>> 'new'
>> /usr/include/asm-i486/system.h: In function 'long unsigned int
>> __cmpxchg(volatile void*, long unsigned int, long unsigned int)':
>> /usr/include/asm-i486/system.h:276: error: 'size' was not declared in this
>> scope
>> /usr/include/asm-i486/system.h:280: error: expected type-specifier before
>> ')' token
>> /usr/include/asm-i486/system.h:286: error: expected type-specifier before
>> ')' token
>> /usr/include/asm-i486/system.h:292: error: expected type-specifier before
>> ')' token
>> /usr/include/asm-i486/system.h:306: error: 'u8' has not been declared
>> /usr/include/asm-i486/system.h:307: error: 'u16' has not been declared
>> /usr/include/asm-i486/system.h:308: error: 'u32' has not been declared
>> /usr/include/asm-i486/system.h:311: error: expected ',' or '...' before
>> 'new'
>> cmpxchg_386(volatile void*, long unsigned int, long unsigned int)':
>> /usr/include/asm-i486/system.h:313: error: 'size' was not declared in this
>> scope
>> /usr/include/asm-i486/system.h:315: error: expected type-specifier before
>> ')' token
>> /usr/include/asm-i486/system.h:315: error: invalid conversion from 'int*'
>> to 'int'
>> /usr/include/asm-i486/system.h:315: error:   initializing argument 3 of
>> 'long unsigned int cmpxchg_386_u8(volatile void*, int, int)'
>> /usr/include/asm-i486/system.h:317: error: expected type-specifier before
>> ')' token
>> /usr/include/asm-i486/system.h:317: error: invalid conversion from 'int*'
>> to 'int'
>> /usr/include/asm-i486/system.h:317: error:   initializing argument 3 of
>> 'long unsigned int cmpxchg_386_u16(volatile void*, int, int)'
>> /usr/include/asm-i486/system.h:319: error: expected type-specifier before
>> ')' token
>> /usr/include/asm-i486/system.h:319: error: invalid conversion from 'int*'
>> to 'int'
>> /usr/include/asm-i486/system.h:319: error:   initializing argument 3 of
>> 'long unsigned int cmpxchg_386_u32(volatile void*, int, int)'
>> /usr/include/linux/bitmap.h: At global scope:
>> /usr/include/linux/bitmap.h:116: error: expected ',' or '...' before 'new'
>> /usr/include/linux/bitmap.h:118: error: expected ',' or '...' before 'new'
>> /usr/include/linux/bitmap.h: In function 'void bitmap_zero(long unsigned
>> int*, int)':
>> /usr/include/linux/bitmap.h:131: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h:134: error: 'BITS_TO_LONGS' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'void bitmap_fill(long unsigned
>> int*, int)':
>> /usr/include/linux/bitmap.h:141: error: 'BITS_TO_LONGS' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h:146: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'void bitmap_copy(long unsigned
>> int*, const long unsigned int*, int)':
>> /usr/include/linux/bitmap.h:152: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h:155: error: 'BITS_TO_LONGS' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'void bitmap_and(long unsigned
>> int*, const long unsigned int*, const long unsigned int*, int)':
>> /usr/include/linux/bitmap.h:163: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'void bitmap_or(long unsigned
>> /usr/include/linux/bitmap.h:172: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'void bitmap_xor(long unsigned
>> /usr/include/linux/bitmap.h:181: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'void bitmap_andnot(long unsigned
>> /usr/include/linux/bitmap.h:190: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'void bitmap_complement(long
>> /usr/include/linux/bitmap.h:199: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'int bitmap_equal(const long
>> /usr/include/linux/bitmap.h:208: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'int bitmap_intersects(const long
>> /usr/include/linux/bitmap.h:217: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'int bitmap_subset(const long
>> /usr/include/linux/bitmap.h:226: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'int bitmap_empty(const long
>> /usr/include/linux/bitmap.h:234: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'int bitmap_full(const long
>> /usr/include/linux/bitmap.h:242: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'int bitmap_weight(const long
>> /usr/include/linux/bitmap.h:250: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'void bitmap_shift_right(long
>> unsigned int*, const long unsigned int*, int, int)':
>> /usr/include/linux/bitmap.h:258: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/bitmap.h: In function 'void bitmap_shift_left(long
>> /usr/include/linux/bitmap.h:267: error: 'BITS_PER_LONG' was not declared
>> in
>> this scope
>> /usr/include/linux/cpumask.h: At global scope:
>> /usr/include/linux/cpumask.h:88: error: 'bits' has not been declared
>> /usr/include/linux/cpumask.h:88: error: expected identifier before numeric
>> constant
>> /usr/include/linux/cpumask.h:88: error: expected ',' or '...' before
>> numeric constant
>> /usr/include/linux/cpumask.h: In function 'void __cpu_set(int, volatile
>> cpumask_t*)':
>> /usr/include/linux/cpumask.h:94: error: 'volatile struct cpumask_t' has no
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'void __cpu_clear(int, volatile
>> cpumask_t*)':
>> /usr/include/linux/cpumask.h:100: error: 'volatile struct cpumask_t' has
>> no
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'void __cpus_setall(cpumask_t*,
>> int)':
>> /usr/include/linux/cpumask.h:106: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h: In function 'void __cpus_clear(cpumask_t*,
>> int)':
>> /usr/include/linux/cpumask.h:112: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h: In function 'int __cpu_test_and_set(int,
>> cpumask_t*)':
>> /usr/include/linux/cpumask.h:121: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h: In function 'void __cpus_and(cpumask_t*,
>> const cpumask_t*, const cpumask_t*, int)':
>> /usr/include/linux/cpumask.h:128: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h:128: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'void __cpus_or(cpumask_t*,
>> const
>> /usr/include/linux/cpumask.h:135: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h:135: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'void __cpus_xor(cpumask_t*,
>> /usr/include/linux/cpumask.h:142: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h:142: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'void __cpus_andnot(cpumask_t*,
>> /usr/include/linux/cpumask.h:150: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h:150: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> member named 'bits'
>> __cpus_complement(cpumask_t*, const cpumask_t*, int)':
>> /usr/include/linux/cpumask.h:157: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h:157: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'int __cpus_equal(const
>> /usr/include/linux/cpumask.h:164: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'int __cpus_intersects(const
>> /usr/include/linux/cpumask.h:171: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'int __cpus_subset(const
>> /usr/include/linux/cpumask.h:178: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'int __cpus_empty(const
>> cpumask_t*, int)':
>> /usr/include/linux/cpumask.h:184: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'int __cpus_full(const
>> cpumask_t*, int)':
>> /usr/include/linux/cpumask.h:190: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'int __cpus_weight(const
>> cpumask_t*, int)':
>> /usr/include/linux/cpumask.h:196: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> __cpus_shift_right(cpumask_t*, const cpumask_t*, int, int)':
>> /usr/include/linux/cpumask.h:204: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h:204: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> __cpus_shift_left(cpumask_t*, const cpumask_t*, int, int)':
>> /usr/include/linux/cpumask.h:212: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h:212: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'int __cpumask_scnprintf(char*,
>> int, const cpumask_t*, int)':
>> /usr/include/linux/cpumask.h:273: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'int __cpumask_parse(const
>> char*,
>> int, cpumask_t*, int)':
>> /usr/include/linux/cpumask.h:281: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h: In function 'int __cpulist_scnprintf(char*,
>> /usr/include/linux/cpumask.h:289: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'int __cpulist_parse(const
>> char*,
>> cpumask_t*, int)':
>> /usr/include/linux/cpumask.h:295: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h: In function 'int __cpu_remap(int, const
>> /usr/include/linux/cpumask.h:303: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> member named 'bits'
>> /usr/include/linux/cpumask.h: In function 'void __cpus_remap(cpumask_t*,
>> const cpumask_t*, const cpumask_t*, const cpumask_t*, int)':
>> /usr/include/linux/cpumask.h:311: error: 'struct cpumask_t' has no member
>> named 'bits'
>> /usr/include/linux/cpumask.h:311: error: 'const struct cpumask_t' has no
>> member named 'bits'
>> member named 'bits'
>> member named 'bits'
>> /usr/include/asm-i486/processor.h: At global scope:
>> /usr/include/asm-i486/processor.h:80: error: 'CONFIG_X86_L1_CACHE_SHIFT'
>> was not declared in this scope
>> /usr/include/asm-i486/processor.h:80: error: requested alignment is not a
>> constant
>> /usr/include/asm-i486/processor.h: In function 'void set_in_cr4(long
>> unsigned int)':
>> /usr/include/asm-i486/processor.h:246: error: 'read_cr4' was not declared
>> in this scope
>> /usr/include/asm-i486/processor.h:248: error: 'write_cr4' was not declared
>> in this scope
>> /usr/include/asm-i486/processor.h: In function 'void clear_in_cr4(long
>> unsigned int)':
>> /usr/include/asm-i486/processor.h:255: error: 'read_cr4' was not declared
>> in this scope
>> /usr/include/asm-i486/processor.h:257: error: 'write_cr4' was not declared
>> in this scope
>> load_esp0(tss_struct*,
>> thread_struct*)':
>> /usr/include/asm-i486/processor.h:500: error: 'unlikely' was not declared
>> in this scope
>> make[2]: *** [Core.lo] Error 1
>> make[1]: *** [all-recursive] Error 1
>> make: *** [all] Error 2
>> DWFCORE 1.0: Error build failed (0).................
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Mapguide-2.0.1.2716-build-problem-tp18763921p18772780.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
