[mapguide-users] How to export a WebLayouts toolbox and menu
configuration
James Card
James.Card at calcad.com
Fri Aug 1 11:15:39 EDT 2008
On Fri, 01 Aug 2008 06:35:04 -0700, stoff <mail at effing.org> wrote:
> is it possible to export/import the mapguide Weblayout configuration of
> the toolbox/contextmenu/task -commands? I don't want to repeat all
> changes in the configuration on every machine I deploy ... or is it
> possible to put it into a package?
Yes, it is possible to create a package that contains just a single web
layout.
It will contain a reference to the map resource. If you wanted to use the
same toolbox/contextmenu/task setting in a layout that references a
different map you might be better to save the layouts as XML files and
then merge the toolbox/contextmenu/task sections from the source XML file
into the target XML, then reload the modified XML file for the layout onto
the target server.
James Card
California CAD Solutions, Inc.
209-578-5580 - Voice
209-521-6493 - FAX
