[mapguide-users] How to export a WebLayouts toolbox and menu configuration
stoff mail at effing.org
Wed Aug 6 08:33:02 EDT 2008
Hi James,
thanks for your answer, I'll try out ... and report about it!
Best regards,
stoff
James Card wrote:
> On Fri, 01 Aug 2008 06:35:04 -0700, stoff <mail at effing.org> wrote:
>> is it possible to export/import the mapguide Weblayout configuration of
>> the toolbox/contextmenu/task -commands? I don't want to repeat all
>> changes in the configuration on every machine I deploy ... or is it
>> possible to put it into a package?
> Yes, it is possible to create a package that contains just a single web
> layout.
> It will contain a reference to the map resource. If you wanted to use the
> same toolbox/contextmenu/task setting in a layout that references a
> different map you might be better to save the layouts as XML files and
> then merge the toolbox/contextmenu/task sections from the source XML file
> into the target XML, then reload the modified XML file for the layout onto
> the target server.
> James Card
> California CAD Solutions, Inc.
> 209-578-5580 - Voice
> 209-521-6493 - FAX
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/How-to-export-a-WebLayouts-toolbox-and-menu-configuration-tp18774434p18850208.html
